snow05gtRI Posted December 11, 2009 Share Posted December 11, 2009 and apply scalar and latency values the last person tuned them for, does that make them work for my car? basically - buying used injectors, person says they will give scalar and latencies they tuned their car with, i dont tune myself but my tune is OS and i can probably figure out where the numbers go after i download my map and open it in RR (i have downloaded it before, so i know that step). does this only work if i had the same fuel pump? Link to comment Share on other sites More sharing options...
NSFW Posted December 11, 2009 Share Posted December 11, 2009 That will probably work, or at least get you close. However, without a wideband O2 sensor to verify your AFRs at full throttle, it's impossible to know for sure how close (or how far off) the settings are. If the person you're getting them from has the exact same air intake and MAF housing that you have, then the odds of success go up. In that case I'd do the following: 0) Using Learning View to see what your AF Learning values are, and the knock correction table, and the IAM. 1) If those aren't healthy, stop here. 2) Log several pulls, 3rd gear, 2500rpm to redline 3) Look at the logs and see how much you're knocking 4) If the answer is "in every pull" then stop here. 5) Install injectors 6) Set latency and scaling as per the seller's specs 7) Drive around, without getting into boost. 8) Verify the AF learning again. If not acceptable, stop here. 9) Log 2500-3500 at WOT, check for knock. 10) Repeat, working your way up to redline, checking for knock with each step. It would take a while, but if you get to where you can do WOT pulls without knocking (or with negligible knock) then the exact AFR isn't that important. I can explain terms like "acceptable" in more detail if you're interested in actually doing this. If you're going to be modding your car, you owe it to yourself to learn to log anyway. It's the only way to know if your engine is healthy. It's OK to trust your tuner, but only if you verify. Link to comment Share on other sites More sharing options...
snow05gtRI Posted December 11, 2009 Author Share Posted December 11, 2009 thank you for the explanation, it is very much appreciated. if i make the jump and buy the injectors I will come back for your more detailed explanation. Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted December 11, 2009 Share Posted December 11, 2009 I think it would be valuable to know your learning values on your current tune before you install new injectors. It gives you something to compare. Even completely stock cars will have some level of A/F correction to account for normal changes in the weather and in the engine. On the search for a new DD... Link to comment Share on other sites More sharing options...
bugblatterbeast Posted December 15, 2009 Share Posted December 15, 2009 don't forget to rescale cranking PW. there are also a few CL to OL thresholds which will need adjustment Link to comment Share on other sites More sharing options...
Ridgeracer Posted December 16, 2009 Share Posted December 16, 2009 don't forget to rescale cranking PW. there are also a few CL to OL thresholds which will need adjustment Got a link for this process on RR? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
yamie700 Posted December 17, 2009 Share Posted December 17, 2009 Got a link for this process on RR? +1, when I've done injectors I just adjust latency, scalar, and tip in. What else is needed? Link to comment Share on other sites More sharing options...
snow05gtRI Posted December 17, 2009 Author Share Posted December 17, 2009 i was looking at your injectors, yamie...but they got taken before i could get them... Link to comment Share on other sites More sharing options...
