Crank Sprocket Removal
During timing belt removal, I noticed that the crank sprocket has some dents on most of the teeth. I need to remove it, but how. I have read all the posted threads out there but there are not exactly how to remove the key that is holding it. Do I yank it out or how?
Any suggestions>?
Thanks..
Manny
You need a puller. The sprocket is secured by a woodruff key. You need to remove the sprocket before you can remove the key.
However I am puzzled how a rubber belt could put any dents in the sprocket. Take a picture and post here.
Why would you pull cam sprockets to do a t belt? Those freaking bolts are on like permanant.
REMOVAL
  1. Remove the V-belts.
  2. Remove the crank pulley.
  3. Remove the timing belt cover.
  4. Remove the timing belt.
  5. Remove the cam sprocket.
http://www.alldatapro.com/alldata/PRO~V145297765~C40575~R0~OB0~P3R0H~N/0/108596970/110824356/110824379/110824385/34853741/100411974/34853743/101452876/34854121/120290459/120290460
  1. Remove the crank sprocket.
INSTALLATION
http://www.alldatapro.com/alldata/PRO~V145297765~C40575~R0~OB0~P3R0H~N/0/108596970/110824356/110824379/110824385/34853741/100411974/34853743/101452876/34854121/120290459/120290461
  1. Install the crank sprocket.
  2. Install the cam sprocket.
Copy and paste from ALLDATA. No mention of a puller but I have my engine in pieces, I'll try and see if it does need a puller tonight for you.
