Cincy05LGT Posted December 3, 2009 Share Posted December 3, 2009 I understand this code signifies fuel cut due to overboosting. I am running the map with 20% reduced WGDC initial and max tables as recommended by MickeyD. Any ideas? 40°F All stock Attached is my last learning view from only a few minutes before the CEL Link to comment Share on other sites More sharing options...
Cincy05LGT Posted December 4, 2009 Author Share Posted December 4, 2009 Bump! Working on this tonight and hoping not to flash back to stock... Please help! Link to comment Share on other sites More sharing options...
SubyShop.com Posted December 4, 2009 Share Posted December 4, 2009 What's your target boost set at? What amount of boost are you hitting? -Franz Link to comment Share on other sites More sharing options...
Cincy05LGT Posted December 4, 2009 Author Share Posted December 4, 2009 How can I post my boost target and boost limit cut tables? N/M, got it! Link to comment Share on other sites More sharing options...
Cincy05LGT Posted December 4, 2009 Author Share Posted December 4, 2009 Boost Limit (Fuel Cut) [Table2D] 8.51 9.75 10.98 12.22 13.46 14.7 9.84 11.27 12.7 14.14 15.88 17.4 Link to comment Share on other sites More sharing options...
Cincy05LGT Posted December 4, 2009 Author Share Posted December 4, 2009 Target Boost [Table3D] 0 12 24 30 36 42 54 95 800 0.00 0.00 0.00 0.00 0.08 0.08 0.15 0.25 2000 0.62 0.62 0.78 1.54 1.47 1.54 1.86 4.01 2400 0.62 0.62 2.78 4.95 6.18 6.50 6.65 8.40 2800 0.62 0.62 3.25 7.11 8.66 9.28 9.61 12.79 3600 0.62 0.62 1.86 6.50 8.20 9.28 11.20 12.79 4000 0.62 0.62 0.62 4.64 7.11 8.35 10.39 12.79 4800 0.62 0.62 0.62 2.63 5.57 7.27 8.80 11.60 5200 0.62 0.62 0.62 1.86 4.64 6.50 8.15 10.80 5600 0.62 0.62 0.62 1.08 3.71 5.72 7.59 10.24 6000 0.62 0.62 0.62 0.62 3.10 5.26 6.81 9.67 6400 0.62 0.62 0.62 0.62 2.94 4.95 6.50 9.10 6800 0.62 0.62 0.62 0.62 2.63 4.64 5.26 7.20 Link to comment Share on other sites More sharing options...
Cincy05LGT Posted December 4, 2009 Author Share Posted December 4, 2009 Think it is safe to clear the CEL and go back out for a log to catch the overboost? Link to comment Share on other sites More sharing options...
Cincy05LGT Posted December 4, 2009 Author Share Posted December 4, 2009 The first time it threw the CEL I was only around 5psi in 2nd gear lightly accelerating. The second time, it was maybe around 7psi. Link to comment Share on other sites More sharing options...
Cincy05LGT Posted December 4, 2009 Author Share Posted December 4, 2009 Bump! Link to comment Share on other sites More sharing options...
Cincy05LGT Posted December 4, 2009 Author Share Posted December 4, 2009 Apparently in the latest Romraider defs the boost limit is now in terms of absolute pressure instead of relative to sealevel. I added 14.7 to each of the values. Link to comment Share on other sites More sharing options...
liloaty Posted December 8, 2009 Share Posted December 8, 2009 Did you add 14.7 to the fuel cut limit or to the target boost table? Link to comment Share on other sites More sharing options...
Cincy05LGT Posted December 8, 2009 Author Share Posted December 8, 2009 boost fuel cut Link to comment Share on other sites More sharing options...
