IAG Performance Posted December 3, 2009 Share Posted December 3, 2009 http://www.iagperformance.com/images/forum/nasioc/service/image_01_800.jpg Visit IAG Performance for service between now and the end of the year to receive discounts off all of our regular MAIC Service Special Thread prices! See below for 5% off of ALL of our normal Service Specials. The best service deals in the area just got better! Call, PM, or email to schedule your service today! Holiday FREE Alignment Check Special Through the end of the year, we are offering a free alignment check using our floor mounted Hunter RX Scissor Lift Rack and HawkEye High Definition Digital Imaging Wheel Alignment System. A quality alignment is essential for safety/drivability, good handling, and consistent tire wear. Through the end of the year, we will check your alignment 100% free-of-charge, and supply a thorough printout of alignment results for your records. Once you’re on the rack, if you decide to have us perform a 4-wheel alignment, we are offering 5% off our regular alignment price of $99! Join hundreds of other Subaru owners in the area who have experienced the IAG Performance Alignment… Satisfaction guaranteed! Holiday Dyno-Pull Special 3 Runs on our DynoJet with AFR and Boost and print-out - $99 After your base runs, if you decide to Pro Tune with us, you will receive your $99 back toward tuning! Also, see further down in our thread for our Holiday Pro Tuning Special!!! :ritz: IAG Performance Subaru Scheduled Maintenance Services http://iagperformance.com/images/forum/nasioc/service/special/image_05_800.jpg 30,000 & 90,000 Mile Service - Was $399 - Now $379 -Oil change using your choice of Motul, Eneos or Valvoline Synthetics -K&N or Purolator Pure One Oil Filter & new drain plug washer -Replace Transmission Fluid w/ Motul 75w90 (other fluids available upon request) -Replace Differential Fluid w/ Motul 75w90 (WRX) or Motul PA 90 (STi) -Coolant flush and inspect cooling system, hoses and connections. Global coolant w/ 1 bottle of Motul MoCool -Air Filter Service (replace factory filter w/ K&N Drop-In, or clean & lubricate existing filter) -Flush & replace brake fluid w/ your choice of Ate SuperBlue or Motul DOT 5.1 -Inspect brake pads and rotors -Inspect brake lines and check operation of parking brake -Inspect Front & Rear axle boots and axle shaft joint portions -Inspect clutch operation -Inspect Steering & Suspension -Inspect tires & rotate -PCV Valve -Top-off all fluids -Replace fuel filter and inspect fuel system 60,000 Mile Service - Was $499 - Now $474 -All services performed in 30K Service -Change spark plugs http://iagperformance.com/images/forum/nasioc/service/special/image_04_800.jpg 105,000 Mile Service - Was $899 - Now $854 -Replace Timing belt -Replace water pump & water pump gasket -Replace thermostat & thermostat gasket -Flush coolant & inspect cooling system. Global coolant w/ 1 bottle of Red Line Water Wetter or Motul MoCool -Crank Seal -A/C & P/S Belts -Cam Seals -Timing belt tensioner Timing Belt/Water Pump Service Only - Was $499 - Now $474 Brake Packages http://iagperformance.com/images/forum/nasioc/service/special/image_07_800.jpg Stage 1 Hawk HPS Front/Rear Pads Techna-Fit SS brake lines Motul DOT 5.1 or Ate SuperBlue WRX - Was $449 - Now $426 Installed STi - Was $499 - Now $474 Installed Stage 2 Hawk HPS Front/Rear Pads RacingBrake SS brake lines Motul DOT 5.1 or Ate SuperBlue RacingBrake Slotted or Cross-Drilled & Slotted Rotors WRX - Was $949 - Now $901 Installed STi - Was $1099 - Now $1044 Installed Suspension Services http://iagperformance.com/images/forum/nasioc/service/special/image_06_800.jpg Alignment/Corner Balancing Performance Alignment - Was $99 -Now $94 Performance Alignment & Corner Balancing - Was $199 - Now $189 Install Springs/Coilovers (purchased @ IAG) w/ Performance Alignment - Was $250 - Now $237 Install Customer supplied springs & alignment - Was $349 - Now $331 Install Customer supplied coilovers & alignment - Was $399 - Now$379 Transmission Services http://iagperformance.com/images/forum/nasioc/service/special/image_08_800.jpg Exedy Stage 1 clutch package – w/ resurfaced flywheel & Motul or Eneos 75w90 fluid WRX - Was $899 - Now $854 Installed STi - Was $999 - Now $949 Installed Exedy Twin-Plate clutch package w/ performance flywheel & Motul or Eneos 75w90 fluid WRX - Was $1899 - Now $1804 Installed STi - Was $1899 - Now $1804 Installed Other clutch purchased @ IAG installation prices (includes resurfacing flywheel and new fluids) WRX & STi - Was $400 - Now $380! Install customer supplied clutch (includes resurfacing flywheel and new fluids) WRX & STi - Was $495 - Now $470! New ACT Specials (more to come in the following days!) ACT SB5-HDSS - ACT Heavy-Duty Modified Street Clutch with your choice of ACT Streetlite or Subaru OE 06-07 WRX Flywheel - Was $1349 Installed with your choice of fluids!!! - Now $1282! ACT HDSS STI Heavy Duty Street Clutch - ACT Heavy-Duty Modified Street Clutch with resurfaced flywheel for 04-09 STI 6-Speed - Was $1199 Installed with your choice of fluids!!! - Now $1139! Performance Part Installs Downpipe/Turboback (purchased @ IAG) - Was $79 - Now $75 Downpipe/Turboback (customer supplied) - Was $99 - Now $94 Uppipe Install (purchased @ IAG) - Was $225 - Now $213 Uppipe Install (customer supplied) - Was $300 - Now $285 Sway-Bar/end-link Install - Was $79 - Now $75 Upgraded Turbo Install - Please call or PM Front-Mount Intercooler Install - Please call or PM The IAG Performance Rotated Turbo Setup - Please call or PM Installation of thousands of other products for your Subaru - PM for pricing!!! Protuning by Jorge (RiftsWRX) Limited-Time IAG Performance/RiftsWRX Pro Tune and Pre-Dyno Inspection Special For the next few customers who sign up for tuning this month, we will offer Pre-Dyno Inspection FREE OF CHARGE!!! Services included in our FREE Pre-Dyno Inspection include compression test, boost-leak check, exhaust-leak check, and full on-dyno support when you’re being tuned! Our #1 priority is ensuring that our customers are successfully tuned, and our Pre-Dyno is the best way to help achieve that goal! No one else in the area offers this level of tuning preparation… And for a limited-time, we’re offering it for FREE! See Post #2 for details on our Tuning Sessions with Jorge!!! Appearance Services & Window Tint http://iagperformance.com/images/forum/nasioc/service/image_09_800.jpg Window Tinting @ IAG Performance Holiday Special - All Window Tint Services 10% off!!!! Call today to schedule! Our window tinter has been in the business for over 15 years, and does an absolutely incredible job. We offer Johnson high quality window films, available in shades from MD legal all the way to limo dark. Our tinting services come with a lifetime warranty against bubbling, peeling, fading, purpling, hazing, & more. If you're looking for high-quality tint for your Subaru, shoot us a PM or call at the shop any time! Other Appearance Services Recondition headlights - Was $75 - Now $71 Koji-Mod & Paint headlights (your choice of color, typically black) WRX - Was $199 - Now $189 STi - Was $225 - Now $213 Headlight and Taillight Protection Films - Price varies - PM for details! IAG Performance 1203 Baltimore Blvd. Westminster, MD 21157 410-840-3555 www.iagperformance.com sales@iagperformance.com Link to comment Share on other sites More sharing options...
IAG Performance Posted December 3, 2009 Author Share Posted December 3, 2009 http://iagperformance.com/images/forum/nasioc/service/image_10_800.jpg Pro Tuning by Jorge (RiftsWRX) Limited time Special - For the next few customers who sign up for our December Tuning Session - Free Pre-Dyno Inspection!!! As many of you may know IAG and RiftsWRX (Jorge Carillo) have teamed up to bring the MAIC community regular dyno-tuning sessions each month. Jorge has an absolutely outstanding reputation tuning Subarus, and is one of the most renowned Accessport Pro-tuners in the country! How It Works... Tuning spots are available for $500 and you will receive UP TO 2 hours of dyno tuning. Sometimes, it will take the whole session to finish up your tune... Other times, it may take only an hour or so. At this point, if you are satisfied, you are welcome to go on your way. However, if there is enough remaining tuning time, you have the option of adding a second tune for race gas or meth. Many of our tuning customers choose to add a race-gas map in addition to their street maps. Successful preparation leads to successful tuning!!! To tune with us at IAG Performance, we are now requiring that you have a PDI (Pre-Dyno Inspection) performed on your vehicle prior to tuning. This service will need to be performed at our facility sometime in the several weeks prior to tuning. Pre-dyno inspections WILL NOT be performed the weekend of tuning, as we need to have all cars 100% ready to go prior to Jorge flying in. The IAG Performance Pre-Dyno Inspection -IAG performs a compression test and changes plugs if needed -IAG performs both boost and vacuum leak test -IAG checks car over for major oil or exhaust leaks -IAG changes oil and filter (oil & filter sold separately) -IAG looks over car carefully to ensure it is in tunable condition. Pre-Dyno Inspection will be performed at a discounted rate of $99. At most tuning shops, the services offered for our Pre-Dyno Inspection would run roughly $250, but we want to do everything in our power to be sure that these tuning days run as smooth as possible. Performing these services does not necessarily guarantee a 100% perfect tuning day, but it does mean that we have made every effort to come equipped and give the tuner a vehicle that has been fully prepared for Pro-tuning. What happens if there is a problem on the dyno? You receive the full support and expertise of both our owner and lead technician. We will wrench on your car and do everything in our power to ensure a successful tune. Of course, we can never guarantee that every car will go without issues, but this is our guarantee that we will do everything in our power to try to make your tuning day a success! What do we need from you? If you would like to reserve a tuning spot, please PM, email, or call us. We require a $250 deposit to hold your spot. Tuning spots will be sold on a first come first serve basis, and a spot is only considered filled when we receive the deposit. Deposits can be made via Paypal, major credit card by calling us, or in person by cash or check. DO NOT send a deposit without speaking to us first. Please contact us with any questions regarding tuning, installation, pre-dyno, etc. PRIOR to making your deposit, as it is non-refundable (see below) Important Note: If you cannot make your dyno session for any reason, your $250 deposit is NOT refundable. We make a commitment to this session and to our tuner, and we are interested in working with customers who share that same level of commitment. In certain circumstances, if we are able to fill the tuning spot, we can apply your $250 to a future tuning session, should catastrophic circumstances arise. The most important thing to us, is that before you make your deposit, you are 100% committed to tuning! Frequently Asked Questions Where does IAG Tune?As you may have seen in our recent MAIC post, we have completed install of our new in-house DynoJet! Tuning now takes place exclusively at our facility in Westminster, MD! What kind of engine management does Jorge tune at the IAG sessions? The primary tuning device that we tune is the Cobb Accessport. Jorge will also tune stand-alone devices such as AEM for some customers. We DO NOT offer tuning for UTEC or OpenSource. For more details, feel free to call or email with questions. When will I find out my tuning time? We will notify tuning customers some time the week prior to tuning with a finalized schedule. We take customers’ desired times in to consideration, but this does not guarantee that everyone will receive their desired time on the nose (example, typically at least 5 customers want to tune in the first spot on Saturday…) If I have performance upgrades installed on my car prior to the tuning date, will my car be safe to drive until that weekend? Jorge can build a “safe file” for your Cobb AP. We will need at least 1 week lead-time to order these files and have them ready. In short, you can’t beat $500 for up to two pro-tuned maps by one of the best Cobb tuners in the country and the on-hand support of our experienced staff to back you up. We feel that the MAIC community deserves this level of tuning and care and are glad to be a part of it. If you have any questions please PM, call or email the shop. If you can’t make it to this session, don’t worry, there will be many more! Regards, Rick IAG Performance sales@iagperformance.com 410-840-3555 Important note: For tuning specific questions, please feel free to contact Jorge at Jorge@iagperformance.com. DO NOT contact Jorge at P&L Motorsports for any reason. If you need to reach him, contact him via this email address or call here at the shop! http://www.iagperformance.com/images/dyno/protuning/image_02_635.jpg Link to comment Share on other sites More sharing options...
