vlad_b Posted December 3, 2009 Share Posted December 3, 2009 Pending the results of the bolt cutting and extraction that is scheduled for tuesday I might need a new rear bilstein strut. Any idea what is the cheapest way to get it? At subaru it's $285. I don't mind used and I remember seeing here some company that sells used, but now when I need it I can't find it. Link to comment Share on other sites More sharing options...
Polo08816 Posted December 3, 2009 Share Posted December 3, 2009 Pending the results of the bolt cutting and extraction that is scheduled for tuesday I might need a new rear bilstein strut. Any idea what is the cheapest way to get it? At subaru it's $285. I don't mind used and I remember seeing here some company that sells used, but now when I need it I can't find it. http://www.tirerack.com/suspension/suspension.jsp?&make=Bilstein&model=HD+Strut&group=HD+Shock&autoMake=Subaru&autoModel=Legacy+Wagon+2.5+GT+Limited&autoYear=2007&autoModClar=&partNum=F4.VE3.B830.H0&perfCode=S Is this not it? Link to comment Share on other sites More sharing options...
Gire Posted December 3, 2009 Share Posted December 3, 2009 Finding 1 used might be really tough. I've never seen a set advertised that the seller was willing to split it up. I've never seen a partial set for sale either. RalliTek sells the Bilsteins buy the corner, so you could give them a call. http://www.rallitek.com/suspension1.html Link to comment Share on other sites More sharing options...
sactojesse Posted December 3, 2009 Share Posted December 3, 2009 Keep in mind that the Bilstein HD is not the same as the JDM LGT Rev. C Bilsteins that came on USDM Spec Bs. The Bilstein HDs are firmer riding than the relatively soft USDM Spec B Bilsteins. See this thread for details: http://legacygt.com/forums/showthread.php?t=61108 Link to comment Share on other sites More sharing options...
Gire Posted December 3, 2009 Share Posted December 3, 2009 Good point. I wonder how strange an HD set up in the rear, and a Rev C set up in the front would feel like. I'm thinking probably minimal, to the average LGT enthusiast. One corner only with an HD strut doesn't sound like a good idea though! Link to comment Share on other sites More sharing options...
Underdog Posted December 3, 2009 Share Posted December 3, 2009 If you can't find an OEM Bilstein to replace it with, get a pair of HD's from tirerack or some other vendor. IIRC the rear HDs are <$100 per side. Not good to mix and match side to side, front to back is probably okay though. The Crimson Dynamo Link to comment Share on other sites More sharing options...
jagcars26 Posted December 4, 2009 Share Posted December 4, 2009 If you can't find an OEM Bilstein to replace it with, get a pair of HD's from tirerack or some other vendor. IIRC the rear HDs are <$100 per side. Not good to mix and match side to side, front to back is probably okay though. Yea,I'm thinking the same.Get a pair for the rear. Link to comment Share on other sites More sharing options...
Polo08816 Posted December 4, 2009 Share Posted December 4, 2009 The OP's avatar is full of win. Link to comment Share on other sites More sharing options...
