Outback 99 Problem to start
Hi, i have a problem with my Legacy Outback Gt 1999 2.5 Dohc, 57 000 Miles
Last day I tried to start the car... it wouldn't want to start !!!! I held the starter and put a little throttle... after about 60 miss the car started.... and ran stable.... then I noticed a check engine, the code is DTC P010F (Mass or Volume Air Flow Sensor A/B Correlation).
While the car is still cold, if I touch the throttle. the car stall.
If I wait till its hot, it doesn't stall.
I changed the Mass Air Flow.... no difference... and the check engine remains.
When I started working on this problem, the Radiator fans would not stop. they ran all the time even with the engine cold and stopped.
Also the temperature is not raising in the dash.
Right not I'm thinking a CAT problem, but I never had a car with two CAT before, so I'm not sure how to deal with that.
Anyone have idea how I could fix that ? Thanks
Do you have some idea to check ?
Thank you in advance for your help.
