Alignment questions
jmorris6689
2005 LGTL Wagon - Daily driver, Monte Carlo Rally and mountain/canyon carving
Camber: -.75* F, -1.0* R, 0* cross-camber (4BoxParts Rear Lower Adjustable Links)
Toe: 0* all around
Caster: AVO LCA offset bushings ~+5*caster
Roll-center kit: Whiteline RCK to compensate for 1.5" Bilstein/Swift Sport Spring suspension drop
  • 2 weeks later...
  • 4 months later...
  • 3 weeks later...
Hi guys,
I just lowered my car, I am planning to bring my car to firestone since I did my alignment there before the lowering. Where did you guys get your custom alignment specs?
Hi guys,
I have mine done at Firestone (Camber -1R/-.5F, Toe 0 F/R, Cross-camber 0).
BTW - How much did you drop it? If more than 3/4" I suggest (strongly recommend) you go with a roll-center kit to pull your front camber back into line. You won't be able to get it back to -1ish without it.
