boostsr20 Posted November 18, 2009 Share Posted November 18, 2009 Looking to find out if the 2009 suspension setup is the same mounting wise as the 2005 GT's. Link to comment Share on other sites More sharing options...
Darkness of Death Posted November 18, 2009 Share Posted November 18, 2009 why would it be different? it's the same generation Link to comment Share on other sites More sharing options...
Drew888 Posted November 19, 2009 Share Posted November 19, 2009 How about a more direct answer.... Yes they are identical. [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
m sprank Posted November 19, 2009 Share Posted November 19, 2009 Completely identical. Link to comment Share on other sites More sharing options...
Darkness of Death Posted November 19, 2009 Share Posted November 19, 2009 How about a more direct answer.... it increases the self doubt a little more Link to comment Share on other sites More sharing options...
boostsr20 Posted November 20, 2009 Author Share Posted November 20, 2009 Good to know because someone used some LGT springs on a tribeca with LGT front top hats. I have a set of springs laying around that I may throw on my Tribeca. Link to comment Share on other sites More sharing options...
whitetiger Posted November 20, 2009 Share Posted November 20, 2009 tribecca uses the outback platform with works with legacy springs. so you should be fine. Link to comment Share on other sites More sharing options...
Gmachine Posted November 20, 2009 Share Posted November 20, 2009 I would dig a little deeper into the spring information before jumping in. A Tribeca is about 4,200 lbs. Legacys are closer to 3,500 lbs. I think the spring rates for the Tribeca would be higher,how much is the question. Link to comment Share on other sites More sharing options...
AZP Installs Posted November 23, 2009 Share Posted November 23, 2009 Yeah, they may physically fit on a tribeca but I'm not sure how well they will work or how safe it will be to drive it. -mike Link to comment Share on other sites More sharing options...
boostsr20 Posted November 24, 2009 Author Share Posted November 24, 2009 From what I gather the shocks used on the tribeca valved for the heavier weight. I am thinking that if I do this, I will probably pick up a set of Spec B sprigns for the slightly higher rate. Link to comment Share on other sites More sharing options...
whitetiger Posted November 25, 2009 Share Posted November 25, 2009 be careful witht he spec b springs. you may have ride height issues. Link to comment Share on other sites More sharing options...
