Link to list of OBD codes anyone?
Hate to do this as I know it is here somewhere but I can't find it under any reasonable keyword search. Looking for the complete list of diagnostic codes valid for 2005 LGT as reported by the on board diagnostics system. When I find it I'll bookmark it! I promise.
And thanks to the user who originally posted this list.
Chris
From this website: http://www.obd-codes.com/trouble_codes/
P0010-P0099 - Fuel and Air Metering and Auxiliary Emission Controls
  • P0010 "A" Camshaft Position Actuator Circuit (Bank 1)
  • P0011 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
  • P0012 "A" Camshaft Position - Timing Over-Retarded (Bank 1)
  • P0013 "B" Camshaft Position - Actuator Circuit (Bank 1)
  • P0014 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1) - See Trouble Code P0011
  • P0015 "B" Camshaft Position -Timing Over-Retarded (Bank 1) - See Trouble Code P0012
  • P0020 "A" Camshaft Position Actuator Circuit (Bank 2)
  • P0021 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
  • P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
  • P0023 "B" Camshaft Position - Actuator Circuit (Bank 2) - See Trouble Code P0020
  • P0024 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2) - See Trouble Code P0021
  • P0025 "B" Camshaft Position - Timing Over-Retarded (Bank 2) - See Trouble Code P0022
  • P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
  • P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
  • P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
  • P0033 Turbo Charger Bypass Valve Control Circuit
  • P0034 Turbo Charger Bypass Valve Control Circuit Low
  • P0035 Turbo Charger Bypass Valve Control Circuit High
  • P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
  • P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
  • P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
  • P0040 Upstream Oxygen Sensors Swapped From Bank To Bank
  • P0041 Downstream Oxygen Sensors Swapped From Bank To Bank
  • P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
  • P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
  • P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
  • P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
  • P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
  • P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
  • P0053 HO2S Heater Resistance (Bank 1, Sensor 1)
  • P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
  • P0055 HO2S Heater Resistance (Bank 1, Sensor 3)
  • P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
  • P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
  • P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
  • P0059 HO2S Heater Resistance (Bank 2, Sensor 1)
  • P0060 HO2S Heater Resistance (Bank 2, Sensor 2)
  • P0061 HO2S Heater Resistance (Bank 2, Sensor 3)
  • P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
  • P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
  • P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
  • P0065 Air Assisted Injector Control Range/Performance
  • P0066 Air Assisted Injector Control Circuit or Circuit Low
  • P0067 Air Assisted Injector Control Circuit High
  • P0070 Ambient Air Temperature Sensor Circuit
  • P0071 Ambient Air Temperature Sensor Range/Performance
  • P0072 Ambient Air Temperature Sensor Circuit Low Input
  • P0073 Ambient Air Temperature Sensor Circuit High Input
  • P0074 Ambient Air Temperature Sensor Circuit Intermittent
  • P0075 Intake Valve Control Solenoid Circuit (Bank 1)
  • P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
  • P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
  • P0078 Control Solenoid Circuit (Bank 1)
  • P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
  • P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
  • P0081 Intake valve Control Solenoid Circuit (Bank 2)
  • P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
  • P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
  • P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
  • P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
  • P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
DTC Codes - P0100-P0199 - Fuel and Air Metering
Edited by Bolksey85
DTC Codes - P0200-P0299 - Fuel and Air Metering (Injector Circuit)
  • P0200 Injector Circuit Malfunction
  • P0201 Injector Circuit Malfunction - Cylinder 1
  • P0202 Injector Circuit Malfunction - Cylinder 2
  • P0203 Injector Circuit Malfunction - Cylinder 3
  • P0204 Injector Circuit Malfunction - Cylinder 4
  • P0205 Injector Circuit Malfunction - Cylinder 5
  • P0206 Injector Circuit Malfunction - Cylinder 6
  • P0207 Injector Circuit Malfunction - Cylinder 7
  • P0208 Injector Circuit Malfunction - Cylinder 8
  • P0209 Injector Circuit Malfunction - Cylinder 9
  • P0210 Injector Circuit Malfunction - Cylinder 10
  • P0211 Injector Circuit Malfunction - Cylinder 11
  • P0212 Injector Circuit Malfunction - Cylinder 12
  • P0213 Cold Start Injector 1 Malfunction
  • P0214 Cold Start Injector 2 Malfunction
  • P0215 Engine Shutoff Solenoid Malfunction
  • P0216 Injection Timing Control Circuit Malfunction
  • P0217 Engine Overtemp Condition
  • P0218 Transmission Over Temperature Condition
  • P0219 Engine Overspeed Condition
  • P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
  • P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
  • P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
  • P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
  • P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
  • P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
  • P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
  • P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
  • P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
  • P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
  • P0230 Fuel Pump Primary Circuit Malfunction
  • P0231 Fuel Pump Secondary Circuit Low
  • P0232 Fuel Pump Secondary Circuit High
  • P0233 Fuel Pump Secondary Circuit Intermittent
  • P0234 Engine Overboost Condition
  • P0235 Turbocharger Boost Sensor A Circuit Malfunction
  • P0236 Turbocharger Boost Sensor A Circuit Range/Performance
  • P0237 Turbocharger Boost Sensor A Circuit Low
  • P0238 Turbocharger Boost Sensor A Circuit High
  • P0239 Turbocharger Boost Sensor B Malfunction
  • P0240 Turbocharger Boost Sensor B Circuit Range/Performance
  • P0241 Turbocharger Boost Sensor B Circuit Low
  • P0242 Turbocharger Boost Sensor B Circuit High
  • P0243 Turbocharger Wastegate Solenoid A Malfunction
  • P0244 Turbocharger Wastegate Solenoid A Range/Performance
  • P0245 Turbocharger Wastegate Solenoid A Low
  • P0246 Turbocharger Wastegate Solenoid A High
  • P0247 Turbocharger Wastegate Solenoid B Malfunction
  • P0248 Turbocharger Wastegate Solenoid B Range/Performance
  • P0249 Turbocharger Wastegate Solenoid B Low
  • P0250 Turbocharger Wastegate Solenoid B High
  • P0251 Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
  • P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
  • P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
  • P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
  • P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
  • P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
  • P0257 Injection Pump Fuel Metering Control "B" Range/Performance Injector)
  • P0258 Injection Pump Fuel Metering Control "B" Low (Cam/R
  • P0259 Injection Pump Fuel Metering Control "B" High (Cam/R
  • P0260 Injection Pump Fuel Metering Control "B" Intermittent Injector)
  • P0261 Cylinder I Injector Circuit Low
  • P0262 Cylinder I Injector Circuit High
  • P0263 Cylinder I Contribution/Balance Fault
  • P0264 Cylinder 2 Injector Circuit Low
  • P0265 Cylinder 2 Injector Circuit High
  • P0266 Cylinder 2 Contribution/Balance Fault
  • P0267 Cylinder 3 Injector Circuit Low
  • P0268 Cylinder 3 Injector Circuit High
  • P0269 Cylinder 3 Contribution/Balance Fault
  • P0270 Cylinder 4 Injector Circuit Low
  • P0271 Cylinder 4 Injector Circuit High
  • P0272 Cylinder 4 Contribution/Balance Fault
  • P0273 Cylinder 5 Injector Circuit Low
  • P0274 Cylinder 5 Injector Circuit High
  • P0275 Cylinder S Contribution/Balance Fault
  • P0276 Cylinder 6 Injector Circuit Low
  • P0277 Cylinder 6 Injector Circuit High
  • P0278 Cylinder 6 Contribution/Balance Fault
  • P0279 Cylinder 7 Injector Circuit Low
  • P0280 Cylinder 7 Injector Circuit High
  • P0281 Cylinder 7 Contribution/Balance Fault
  • P0282 Cylinder 8 Injector Circuit Low
  • P0283 Cylinder 8 Injector Circuit High
  • P0284 Cylinder 8 Contribution/Balance Fault
  • P0285 Cylinder 9 Injector Circuit Low
  • P0286 Cylinder 9 Injector Circuit High
  • P0287 Cylinder 9 Contribution/Balance Fault
  • P0288 Cylinder 10 Injector Circuit Low
  • P0289 Cylinder 10 Injector Circuit High
  • P0290 Cylinder 10 Contribution/Balance Fault
  • P0291 Cylinder 11 Injector Circuit Low
  • P0292 Cylinder 11 Injector Circuit High
  • P0293 Cylinder 11 Contribution/Balance Fault
  • P0294 Cylinder 12 Injector Circuit Low
  • P0295 Cylinder 12 Injector Circuit High
  • P0296 Cylinder 12 Contribution/Range Fault
DTC Codes - P0300-P0399 - Ignition System or Misfire
  • P0300 Random/Multiple Cylinder Misfire Detected
  • P0301 Cylinder 1 Misfire Detected
  • P0302 Cylinder 2 Misfire Detected
  • P0303 Cylinder 3 Misfire Detected
  • P0304 Cylinder 4 Misfire Detected
  • P0305 Cylinder 5 Misfire Detected
  • P0306 Cylinder 6 Misfire Detected
  • P0307 Cylinder 7 Misfire Detected
  • P0308 Cylinder 8 Misfire Detected
  • P0309 Cylinder 9 Misfire Detected
  • P0310 Cylinder 10 Misfire Detected
  • P0311 Cylinder 11 Misfire Detected
  • P0312 Cylinder 12 Misfire Detected
  • P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
  • P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
  • P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
  • P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
  • P0325 Knock Sensor 1 Circuit Malfunction (Bank I or Single Sensor)
  • P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
  • P0327 Knock Sensor 1 Circuit Low Input (Bank I or Single Sensor)
  • P0328 Knock Sensor 1 Circuit High Input (Bank I or Single Sensor)
  • P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
  • P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
  • P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
  • P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
  • P0333 Knock Sensor 2 Circuit High Input (Bank 2)
  • P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
  • P0335 Crankshaft Position Sensor A Circuit Malfunction
  • P0336 Crankshaft Position Sensor A Circuit Range/Performance
  • P0337 Crankshaft Position Sensor A Circuit Low Input
  • P0338 Crankshaft Position Sensor A Circuit High Input
  • P0339 Crankshaft Position Sensor A Circuit Intermittent
  • P0340 Camshaft Position Sensor Circuit Malfunction
  • P0341 Camshaft Position Sensor Circuit Range/Performance
  • P0342 Camshaft Position Sensor Circuit Low Input
  • P0343 Camshaft Position Sensor Circuit High Input
  • P0344 Camshaft Position Sensor Circuit Intermittent
  • P0350 Ignition Coil Primary/Secondary Circuit Malfunction
  • P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
  • P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
  • P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
  • P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
  • P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
  • P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
  • P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
  • P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
  • P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
  • P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
  • P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
  • P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
  • P0370 Timing Reference High Resolution Signal A Malfunction
  • P0371 Timing Reference High Resolution Signal A Too Many Pulses
  • P0372 Timing Reference High Resolution Signal A Too Few Pulses
  • P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
  • P0374 Timing Reference High Resolution Signal A No Pulses
  • P0375 Timing Reference High Resolution Signal B Malfunction
  • P0376 Timing Reference High Resolution Signal B Too Many Pulses
  • P0377 Timing Reference High Resolution Signal B Too Few Pulses
  • P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
  • P0379 Timing Reference High Resolution Signal B No Pulses
  • P0380 Glow Plug/Heater Circuit "A" Malfunction
  • P0381 Glow Plug/Heater Indicator Circuit Malfunction
  • P0382 Exhaust Gas Recirculation Flow Malfunction
  • P0385 Crankshaft Position Sensor B Circuit Malfunction
  • P0386 Crankshaft Position Sensor B Circuit Range/Performance
  • P0387 Crankshaft Position Sensor B Circuit Low Input
  • P0388 Crankshaft Position Sensor B Circuit High Input
  • P0389 Crankshaft Position Sensor B Circuit Intermittent
DTC Codes - P0400-P0499 - Auxiliary Emissions Controls
Edited by Bolksey85
DTC Codes - P0500-P0599 - Vehicle Speed Controls and Idle Control System
  • P0500 Vehicle Speed Sensor Malfunction
  • P0501 Vehicle Speed Sensor Range/Performance
  • P0502 Vehicle Low Input
  • P0503 Vehicle Speed Sensor Intermittent/Erratic/High
  • P0505 Idle Control System Malfunction
  • P0506 Idle Control System RPM Lower Than Expected
  • P0507 Idle Control System RPM Higher Than Expected
  • P0510 Closed Throttle Position Switch Malfunction
  • P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
  • P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
  • P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
  • P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
  • P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
  • P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
  • P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
  • P0533 A/C Refrigerant Pressure Sensor Circuit High Input
  • P0534 Air Conditioner Refrigerant Charge Loss
  • P0550 Power Steering Pressure Sensor Circuit Malfunction
  • P0551 Power Steering Pressure Sensor Circuit Range/Performance
  • P0552 Power Steering Pressure Sensor Circuit Low Input
  • P0553 Power Steering Pressure Sensor Circuit High Input
  • P0554 Power Steering Pressure Sensor Circuit Intermittent
  • P0560 System Voltage Malfunction
  • P0561 System Voltage Unstable
  • P0562 System Voltage Low
  • P0563 System Voltage High
  • P0565 Cruise Control On Signal Malfunction
  • P0566 Cruise Control Off Signal Malfunction
  • P0567 Cruise Control Resume Signal Malfunction
  • P0568 Cruise Control Set Signal Malfunction
  • P0569 Cruise Control Coast Signal Malfunction
  • P0570 Cruise Control Accel Signal Malfunction
  • P0571 Cruise Control/Brake Switch A Circuit Malfunction
  • P0572 Cruise Control/Brake Switch A Circuit Low
  • P0573 Cruise Control/Brake Switch A Circuit High
  • P0574 Cruise Control Related Malfunction
  • P0575 Cruise Control Related Malfunction
  • P0576 Cruise Control Related Malfunction
  • P0578 Cruise Control Related Malfunction
  • P0579 Cruise Control Related Malfunction
  • P0580 Cruise Control Related Malfunction
DTC Codes - P0600-P0699 - Computer Output Circuit
  • P0600 Serial Communication Link Malfunction
  • P0601 Internal Control Module Memory Check Sum Error
  • P0602 Control Module Programming Error
  • P0603 Internal Control Module Keep Alive Memory (KAM) Error
  • P0604 Internal Control Module Random Access Memory (RAM) Error
  • P0605 Internal Control Module Read Only Memory (ROM) Error
  • P0606 PCM Processor Fault
  • P0608 Control Module VSS Output "A" Malfunction
  • P0609 Control Module VSS Output "B" Malfunction
  • P0620 Generator Control Circuit Malfunction
  • P0621 Generator Lamp "L" Control Circuit Malfunction
  • P0622 Generator Field "F" Control Circuit Malfunction
  • P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
  • P0654 Engine RPM Output Circuit Malfunction
  • P0655 Engine Hot Lamp Output Control Circuit Malfunction
  • P0656 Fuel Level Output Circuit Malfunction
DTC Codes - P0700-P0899 - Transmission
  • P0700 Transmission Control System Malfunction
  • P0701 Transmission Control System Range/Performance
  • P0702 Transmission Control System Electrical
  • P0703 Torque Converter/Brake Switch B Circuit Malfunction
  • P0704 Clutch Switch Input Circuit Malfunction
  • P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
  • P0706 Transmission Range Sensor Circuit Range/Performance
  • P0707 Transmission Range Sensor Circuit Low Input
  • P0708 Transmission Range Sensor Circuit High Input
  • P0709 Transmission Range Sensor Circuit Intermittent
  • P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
  • P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
  • P0712 Transmission Fluid Temperature Sensor Circuit Low Input
  • P0713 Transmission Fluid Temperature Sensor Circuit High Input
  • P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
  • P0715 Input/Turbine Speed Sensor Circuit Malfunction
  • P0716 Input/Turbine Speed Sensor Circuit Range/Performance
  • P0717 Input/Turbine Speed Sensor Circuit No Signal
  • P0718 Input/Turbine Speed Sensor Circuit Intermittent
  • P0719 Torque Converter/Brake Switch B Circuit Low
  • P0720 Output Speed Sensor Circuit Malfunction
  • P0721 Output Speed Sensor Range/Performance
  • P0722 Output Speed Sensor No Signal
  • P0723 Output Speed Sensor Intermittent
  • P0724 Torque Converter/Brake Switch B Circuit High
  • P0725 Engine Speed input Circuit Malfunction
  • P0726 Engine Speed Input Circuit Range/Performance
  • P0727 Engine Speed Input Circuit No Signal
  • P0728 Engine Speed Input Circuit Intermittent
  • P0730 Incorrect Gear Ratio
  • P0731 Gear I Incorrect ratio
  • P0732 Gear 2 Incorrect ratio
  • P0733 Gear 3 Incorrect ratio
  • P0734 Gear 4 Incorrect ratio
  • P0735 Gear 5 Incorrect ratio
  • P0736 Reverse incorrect gear ratio
  • P0740 Torque Converter Clutch Circuit Malfunction
  • P0741 Torque Converter Clutch Circuit Performance or Stuck Off
  • P0742 Torque Converter Clutch Circuit Stock On
  • P0743 Torque Converter Clutch Circuit Electrical
  • P0744 Torque Converter Clutch Circuit Intermittent
  • P0745 Pressure Control Solenoid Malfunction
  • P0746 Pressure Control Solenoid Performance or Stuck Off
  • P0747 Pressure Control Solenoid Stuck On
  • P0748 Pressure Control Solenoid Electrical
  • P0749 Pressure Control Solenoid Intermittent
  • P0750 Shift Solenoid A Malfunction
  • P0751 Shift Solenoid A Performance or Stuck Off
  • P0752 Shift Solenoid A Stuck On
  • P0753 Shift Solenoid A Electrical
  • P0754 Shift Solenoid A Intermittent
  • P0755 Shift Solenoid B Malfunction
  • P0756 Shift Solenoid B Performance or Stock Off
  • P0757 Shift Solenoid B Stuck On
  • P0758 Shift Solenoid B Electrical
  • P0759 Shift Solenoid B Intermittent
  • P0760 Shift Solenoid C Malfunction
  • P0761 Shift Solenoid C Performance or Stuck Off
  • P0762 Shift Solenoid C Stuck On
  • P0763 Shift Solenoid C Electrical
  • P0764 Shift Solenoid C Intermittent
  • P0765 Shift Solenoid D Malfunction
  • P0766 Shift Solenoid D Performance or Stuck Off
  • P0767 Shift Solenoid D Stuck On
  • P0768 Shift Solenoid D Electrical
  • P0769 Shift Solenoid D Intermittent
  • P0770 Shift Solenoid E Malfunction
  • P0771 Shift Solenoid E Performance or Stuck Off
  • P0772 Shift Solenoid E Stuck On
  • P0773 Shift Solenoid E Electrical
  • P0774 Shift Solenoid E Intermittent
  • P0780 Shift Malfunction
  • P0781 1-2 Shift Malfunction
  • P0782 2-3 Shift Malfunction
  • P0783 3-4 Shift Malfunction
  • P0784 4-5 Shift Malfunction
  • P0785 Shift/Timing Solenoid Malfunction
  • P0786 Shift/Timing Solenoid Range/Performance
  • P0787 Shift/Timing Solenoid Low
  • P0788 Shift/Timing Solenoid High
  • P0789 Shift/Timing Solenoid Intermittent
  • P0790 Normal/Performance Switch Circuit Malfunction
  • P0801 Reverse Inhibit Control Circuit Malfunction
  • P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
  • P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
Edited by Bolksey85
  • 9 months later...
I have code P0198 Coming up on my car at the moment. It's the Engine Oil Temperature Sensor Circuit High. Can anyone tell me exactly what this means and how about I go fixing it. From little research I have been able to do it's just a bad sensor but I have the slightest clue on location of this sensor.
Well I actually had just as a difficult time finding out about the sensor at the local Subaru dealership but thankfully after about 4 people and collective thoughts we've figured it out. The Oil Temp Sensor is actually located about 3 inches away from the oil pressure sensor. The oil pressure sensor threads directly downward into the car where as the oil temp sensor about 3 inches further in located under some of the take manifold piping threads in diagonally. They are both located right behind the power steering pump. Thanks for the input though.
  • 3 weeks later...
What could cause a "P1518 Starter Switch Circuit Low Input" code? 2006 LGT manual using the Cobb Stage 1 tune no other mods. I reset it with my code reader but haven't had time to see if it was just a hiccup. Thanks in advance.
Stay Stock Stay Happy
  • 3 years later...
  • 5 months later...
 Share
