Platinum_Racing Posted September 14, 2009 Share Posted September 14, 2009 Actually you could probably pull the wires through the boot a little bit more and either squeeze or expand the metal ends that are on there to make them clip onto the MSD coil. If that won't work those wires will work with those wires. If the MSD boots don't fit you can use the stock ones. Link to comment Share on other sites More sharing options...
tedsan126 Posted September 17, 2009 Author Share Posted September 17, 2009 I was wonderin if you knew how to hook up custom guages. i was planin on doin the air fuel ratio, battery, and possibly a tach Link to comment Share on other sites More sharing options...
Platinum_Racing Posted September 17, 2009 Share Posted September 17, 2009 All gauges require the some of the same wires. Some gauges require other wires for special things. For example, all gauges will require a Ground, a Positive, an Accessory, and an Illumination wire. If you want, you can wire the Illumination wire to the Positive wire so that the guage will be illuminated anytime the car is turned on. You can just wire the accessory wire to the radio accessory wire, which should be colored red, but you should double check on that. All those gauges require those wires. Here are the specifics for each gauge... Air Fuel gauge: Positive, Ground, Accessory (Sometimes), Illumination (Sometimes), and a wire that goes to the O2 sensor. Some Air/Fuel gauges don't need the accessory or the illumination wires. This is beacuse some models automaticly shut off when they no longer sense a signal from the O2 sensor. Some also do not require the illumination wire, since they usually employ multiple LED lights to display information anyway, so you can still read them at night. Battery Gauge: Positive, Ground, Accessory, and Illumination. Tach: Positive, Ground, Accessory, Illumination, and a wire that goes to the ignition coil. Link to comment Share on other sites More sharing options...
tedsan126 Posted September 20, 2009 Author Share Posted September 20, 2009 well i finally got my headers on and i attached the msd coil with a bracket I made. I put in the new plugs, new wires and it runs pretty well. the car sounds a lot better and i do notice that it is more powerful. What are your thoughts on forced induction eg. turbocharging for this car, it's a route i am considering taking Link to comment Share on other sites More sharing options...
tedsan126 Posted September 26, 2009 Author Share Posted September 26, 2009 I got around 600-700 dollars i can spend on parts right now, In your opinion what can i buy that will yield the most results performance wise Link to comment Share on other sites More sharing options...
stevenva Posted February 10, 2011 Share Posted February 10, 2011 I did the MSD "upgrade" and my mileage tanked. An improvment in mileage was the main benefit I was after. I am so pissed! I wish I never did it. Biggest waste of money. The car was running fine before, and after the "upgrade" I really couldn't tell any difference. Any difference was psychological. (after spending the loot for the coil pack, wires and the aluminum plate) Here is my car. http://legacygt.com/forums/showthread.php/msd-coil-into-subaru-step-step-photos-152338.html?t=152338&highlight=msd RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
stevenva Posted February 22, 2011 Share Posted February 22, 2011 Does anyone know where i can find performance parts for my legacy 98' and what things that I can do to make it quicker. Quicker around corners at least.. Sway bars! I finally put some Ralliteks on, and those who say "best bang for the buck" are 100% accurate. I was skeptical about the boasting of improvments in handling. After installing them, those are facts, not boasts or bogus claims. Best thing I did for my car by far. This thing is a blast to drive. Highly recommended. RIP 96 Legacy 2.2 4EAT lost reverse @ 374,000 miles Link to comment Share on other sites More sharing options...
