LegacyDriver Posted August 24, 2009 Share Posted August 24, 2009 Would a leaky valve cover gasket cause overheating? My car is streaming oil from that area, and overheating. I'm having a hell of a time finding this leak, and now it's overheating as well... So yes, would the valve cover gasket cause overheating, or should I be looking for something else? I kinda feel that these two problems have one cause. Thanks for your input. Link to comment Share on other sites More sharing options...
rao Posted August 24, 2009 Share Posted August 24, 2009 A valve cover leak will not cause overheating. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
blackfang Posted August 24, 2009 Share Posted August 24, 2009 +1 [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
LegacyDriver Posted August 24, 2009 Author Share Posted August 24, 2009 ok so if its not that, would the head gasket leaking cause overheating? Would a head gasket leak be on the passenger side, driver side, or front? Link to comment Share on other sites More sharing options...
blackfang Posted August 25, 2009 Share Posted August 25, 2009 Yes if a headgasket is leaking engine coolant it can overheat. It can leak on either the passenger or drivers side being the heads are on both sides. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
Max Capacity Posted August 25, 2009 Share Posted August 25, 2009 What year car ? Mileage ? What is the coolant level doing in the overflow tank ? What does the dip stick look like ? Milky ? It's possible the HG is leaking compression into the valve cover, breather system and causing the pressure to blow some oil out past the gasket. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
blackfang Posted August 25, 2009 Share Posted August 25, 2009 It's possible the HG is leaking compression into the valve cover, breather system and causing the pressure to blow some oil out past the gasket. Very unlikely but it could happen. Just not often being you have the cylinder head in the way. That is a lot of material for air to work its way past. Now a headgasket leaking both coolant and oil(I have seen those) can cause that as well. It can also make a freaking mess too. [SIZE=1][URL="http://public.fotki.com/blackfang/"]Pics[/URL] [B]08 KawasakiZZR 600- exhaust and other mods 98 Camaro Z/28 HT- some mods......street/strip car 07 Legacy 2.5i- SPT exhaust...daily driver[/B][/SIZE] Link to comment Share on other sites More sharing options...
