Help car keeps stalling!
1-3-2-4
Yesterday we had rainfall of 1 inch an hour.. Ok.. so I head out to work this morning and I noticed the car kind of stumble on start up.. it idled ok.. backed out of the parking space and went to pull out to leave and the car stalled.. and threw a code.. I went to scan the code and it would keep giving me no codes found.. So I managed to get the car to start again and I scanned while running and I got two codes:
P0505 and P0105 also I noticed if I have the car in ACC or On some relays are clicking like crazy someplace under the dash.. And as I pulled the scanner plug out and proceeded to exit the car I saw puddles of water behind the drivers seat! and out of curiosity I went to check the passenger side and the area was damp in that area as well!
did the ECU get damp?
*edit
I got two more codes that it spit out..
P0340
P0120
edit added youtube video
[ame=http://www.youtube.com/watch?v=rSxo3rLHn-4]YouTube - Not running[/ame]
http://img194.imageshack.us/img194/5610/dsc9742s.jpg
http://img188.imageshack.us/img188/5007/dsc9744.jpg
http://img329.imageshack.us/img329/7549/dsc9745.jpg
http://img524.imageshack.us/img524/8734/dsc9746.jpg
Just pulled ECu had a little water inside and some moisture on the connector pins
hmm not good.. seems like the ECu shorted to the water in the housing.. like a spider nest and then the water shorted it?
I don't know if it can be saved..
http://img25.imageshack.us/img25/8765/dsc9752m.jpg
http://img12.imageshack.us/img12/8885/dsc9755.jpg
Good news!! I blow dried the ECU and let it sit for two hours and plugged it back into the car and hooked the battery cable up.. at first it stumbled but it ran like normal no CEL's just the ABS light is still on (don't know where the control unit is in here)
I'm revealed now.. now I can go drive and get this wet vac to use.
Wow! That water got WAY high! Bummer to hear about the ECU getting wet. Not sure how long it'll last after it has had a short. Although, if the car is running fairly normally now, it shouldn't be too big of a deal. I would highly recommend getting another ECU as soon as you have the spare cash though. You don't want that thing to kick the bucket 100 miles from home...
My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters!
Yeah I'm going to do a few tests as well I can always pick up a ECU cheaply anytime. man the thicker mat that the ECU bracket rests on was soaked with water.
The wet vac seems to be doing a good job sucking the water and dampness out.
That sucks. Hopefully all is well after the suck-n-dry period. I'm sure you'll be fine for a while at least. Are the ECU's you have access to new or factory refurbs or what?
just trying to pull the carpet up now.. the bolts for the seats the one in the rear on the drive shaft tunnel due to old age (tried to remove them before but they snapped) are a PITA to remove.. I did get the drivers seat out but shit I think it took something like 120 Ft. LB of me pulling to finally get the bolt out..
going to soak these things in PB blaster!
Yes Sir! and Dremel! I finally just decided to cut the bolt off that I never could removed.. also I took the ABS module out and just as I expected water got inside as well..
the carpet is removed and I'm going to put the seats back in for now.. I think 3 days with no carpet is good for it to dry out inside..
while I have the carpet out I might as well shampoo it as well.
Yup. A good shampooing certainly wouldn't hurt. Bummer about the ABS module. Is it toast or can it be salvaged?
went to work this morning.. also changed my MT oil and rear diff oil just to be safe.
shampooed the carpet which the water was downright nasty.. and took these pics today.
http://img299.imageshack.us/img299/8250/final2b.jpg
http://img299.imageshack.us/img299/2884/subidleaftermath.jpg
That's the ABS light on since the module is still at home.
Much better. :) Carpet looks like it came out pretty clean considering the circumstances. Is the ABS unit going to be put back in or are you going to just go get a replacement?
I will try putting it back in on Friday along with the carpet.
well shit so much for putting the carpet in today it's friken raining and will be all day.. possible total rainfall of one inch.. heh parked the car on the hill this time.
:lol:
I think I need to clean out the IAC all that stumbling when this first happened seems to have caused some gunk..
I hear the best way is to open it up.. however I need to get a new gasket as well
going to rain today but should be ok for Sunday! ABS module cover is back in along with the screws I should of left the passenger seat out to test quickly but I have a wedding to go to..
going to shampoo the carpet in the hatch area lol the diff oil smell lingers for so long :lol:
only thing wrong is lol I think the bolt stripped to hold the back seat down I got one in but the other does not seem to want to go in..
I was just happy to get the carpet in within around 40 min that's including removing the seats and putting everything back plus the clips and the seats.
I still think my XM direct box got killed in action we will see.. if so I planned on getting a new head unit anyways which would require a new unit anyways.
