Which wires are hot?
tmoney2514
I am trying to direct wire a radar detector using the power from the sunroof on my 03 legacy. There are two buttons, one for tilting the sunroof and one for sliding it open and shut. Both have three wires...The first is black, GREEN and a brown-red color. The other button has a black, BLUE, and a brown-red color. Which one can I tap into to power my detector?
None. Those all go to the sunroof motor assembly and control the sunroof. You can't get ground on that side. You need to get your hands on the R50 plug, the 16 pin plug that goes into the sunroof motor. I'm not sure if this is routed with the two plugs that go to the switches.
If you find the 16 cable bundle use the white/blue for power, black for ground. Your radar detector will turn on and off with the ignition.
