fuzzydd Posted August 17, 2009 Share Posted August 17, 2009 My front left keeps rubbing after lowering on Stance LX+'sAt first I had the dampers biased towards soft and it was tearing up my tireSo I got aligned (-0.5 camber on each side), raised it a half inch and turned it to 4 clicks from full hard (stock is 6) and now it only rubs over big bumps and quick elevation changes - running 18x8 +48 on 235/40/18- 14" between hub/fender- finger and half gap between tire and fender- negative 0.5 camber on each side Link to comment Share on other sites More sharing options...
m sprank Posted August 17, 2009 Share Posted August 17, 2009 whats your wheel offset? Link to comment Share on other sites More sharing options...
fuzzydd Posted August 17, 2009 Author Share Posted August 17, 2009 Sorry +48 Link to comment Share on other sites More sharing options...
m sprank Posted August 18, 2009 Share Posted August 18, 2009 Yeah, +45 fits (just), so you might want to look into fender rolling if you still rub with the new alignment. Link to comment Share on other sites More sharing options...
whitetiger Posted August 18, 2009 Share Posted August 18, 2009 +48 needs no roll with a 235 wide tire on a 8" wide wheel. you need more caber, like -1 or more for good measure. Link to comment Share on other sites More sharing options...
rnstein69 Posted August 18, 2009 Share Posted August 18, 2009 This might help a bit: http://www.1010tires.com/WheelOffsetCalculator.asp Link to comment Share on other sites More sharing options...
m sprank Posted August 18, 2009 Share Posted August 18, 2009 +48 needs no roll with a 235 wide tire on a 8" wide wheel. you need more caber, like -1 or more for good measure. This gentleman knows from experience. He is wise. Link to comment Share on other sites More sharing options...
bjmsdrum00 Posted September 11, 2009 Share Posted September 11, 2009 roll them, i love the look of rolled fenders Link to comment Share on other sites More sharing options...
jamal Posted September 11, 2009 Share Posted September 11, 2009 if it's done right a rolled fender should look the same. you need WAY more negative camber up front. Start with 2 degrees. Link to comment Share on other sites More sharing options...
SnowBound BP5 Posted September 11, 2009 Share Posted September 11, 2009 +48 needs no roll with a 235 wide tire on a 8" wide wheel. you need more caber, like -1 or more for good measure. ^^ What he said. I'd do more than -1.0 on the front. But I can't believe your Stance LX is giving you this much problem. Link to comment Share on other sites More sharing options...
