FS (PA) Tein Coilovers/Perrin Sway bars
jasonv
the 05 has a shorter width front than the 08 I know that. measure twice. My cobb front sway is 1" too narrow and my end links blow all the time.
As for the coilovers, do they lower the stock car? I have cobb springs over stock struts. It lowers the car about 1.25 front 1.75 rear. Any change with these over stock?
At their higest setting the coilovers lower the car .75inches and at the lowest setting is around 2inches
As for the sway bars I will have to measure them myself ill get back to u soon about that.
Here the specs on the coilovers.
TEIN BASIC Damper
Installation Manual
Upper Mt. Ft OEM Upper Mt. Rr OEM
EDFC Availability Not Available
Controller Kit Part No. -
Motor Kit Part No. -
Strut Kit Part No. -
FRONT SIDE REAR
RIDE HEIGHT
FRONT
Approx. Height Adjust Range
mm inch Max/Min(mm/inch)
-39 -1.54 -18.0 / -0.71 to -51.0 / -2.01
REAR
-37 -1.46 +13.0 / +0.51 to -59.0 / -2.32
SPRING
FRONT
SPRING RATE / PART No. Replacement Availability
kgf/mm lbs/in Part # Max/Min(kgf/mm-lbs/in)
6 340 SY060-01225 +1.0 / +60.0 to -1.0 / -60.0
REAR
7 390 SV070-01225 +1.0 / +60.0 to -1.0 / -60.0
  • 3 weeks later...
