dbrunone Posted August 16, 2009 Share Posted August 16, 2009 What inputs into ECU learning? Does it just look at knock, and correct for that? Does AFR play a part in it? Any info would be great Link to comment Share on other sites More sharing options...
Spec B Posted August 16, 2009 Share Posted August 16, 2009 I see ECU learning as 3 different things. 1. IAM settling to 1 aka rough correction...assuming the tune is good this should take 20 seconds of driving. 2. The ECU learning where you knock and proactively pulling timing in those regions..aka fine learning knock correction. |This usually takes about 100 miles tops. 3. The ECU learning the fuel trims..this too takes about 100 miles or less with mixed driving. What goes on in this scenario is the ecu tries to hit a 14.7 afr during cruise..if it does not hit the target it adds or removes fuel until it does. It is continually applying a correction within certain MAF ranges. Link to comment Share on other sites More sharing options...
NSFW Posted August 16, 2009 Share Posted August 16, 2009 If you have an OpenPort (http://www.tactrix.com) you can use the Learning View utility (http://www.romraider.com - Forums - Tuning Utilities) to view the AF Learning, IAM, and the knock correction table. Link to comment Share on other sites More sharing options...
dbrunone Posted August 17, 2009 Author Share Posted August 17, 2009 So according to my tuner, I have a "lazy" oxygen senor...as in, my AF ratios when logging my car are "laggy" compared to other LGT's. It isn't throwing any codes though, but it feels like it's learning some hesitation. Could the O2 sensor be causing this? And is it the UP sensor or DP that provides an input to AF ratio? Link to comment Share on other sites More sharing options...
NSFW Posted August 17, 2009 Share Posted August 17, 2009 The front one is the main one, and it's probably what he was referring to. But you should ask just to be sure. Funny things happen to cars with the rear sensor removed, so if your rear sensor is acting up, funny stuff still gonna happen. Link to comment Share on other sites More sharing options...
