mwiener2 Posted June 28, 2009 Share Posted June 28, 2009 Since I've got the engine out, the clutch is out too. Flywheel is ACT Lightweight. It's a bit too light for my tastes. So I might replace it with a WRX one. It's in good shape. Has the pretty marks on it from being slipped a little too much, but otherwise ok. PP has same marks on it as flywheel. Friction disc I think needs to be replaced. It has maybe 1mm before the rivets are exposed on both sides. Throwout bearing needs to be replaced. I can feel grit in the bearings when I spin it by hand. So what do you guys think. Friction disc and bearing.... or do the whole thing? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
mwiener2 Posted July 1, 2009 Author Share Posted July 1, 2009 So here's for giggles. I called ACT to find out how thick the friction disc is when it's new and when it should be replaced. They said that new, it measures 0.315" and should be replaced at 0.25" So I go and measure mine and it comes out to 0.62" I call ACT back and ask if those measurements were for the thickness of one side, or both sides together. They say they are positive that it is for both sides together, but they will have the R&D department look into it. About 2 hours later I get a call back from them saying that they still aren't sure of the measurements, but mine is probably ok. Way to know your product!!! So instead I pulled up a high-res pic of the friction disc and compared it to mine. I estimate that I have a lil over 50% left and will be putting it back in the car with a new WRX flywheel and a new throwout bearing. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
05lgt5spd Posted July 1, 2009 Share Posted July 1, 2009 Wow that makes no sense....let me know what you do, i just picked up a 06 flywheel and i need a good streetable clutch to handle 450tq.... choices, choices. Do you like your act? Link to comment Share on other sites More sharing options...
mwiener2 Posted July 1, 2009 Author Share Posted July 1, 2009 Other than the flywheel being too light, it's been a great clutch. it always holds even if I slip it too much at first. It's easy to drive at low speeds (except for the flywheel) My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
itsme Posted July 2, 2009 Share Posted July 2, 2009 how bad was the light flywheel? I have the Act LWFW and a '06 WRX fw and I'm trying to decide which one to put on. Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
Th3Franz Posted July 2, 2009 Share Posted July 2, 2009 That 5 lb difference would be that noticeable between the LWFW? What's the main downside to the ACT LWFW, wiener? I will be upgrading my clutch and flywheel this winter I think. I am still deciding between the stock WRX FW and an ACT streetlite. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
mwiener2 Posted July 2, 2009 Author Share Posted July 2, 2009 10lb difference ACT LWFW - 14lbs WRX FW - 25lbs My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
itsme Posted July 2, 2009 Share Posted July 2, 2009 10lb difference ACT LWFW - 14lbs WRX FW - 25lbs yes, but, how bad was the LWFW to drive? Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
mwiener2 Posted July 2, 2009 Author Share Posted July 2, 2009 Pain in the ass in traffic. Fine for everything else. I loved it for track use My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
johnAWD Posted July 2, 2009 Share Posted July 2, 2009 Lightweight flywheel for daily/city driving is indeed a pain in the arse. If you are a SERIOUS racer then it's recommended, otherwise the 06 wrx part is probably the right choice. I am going to do the same setup (ACT HDMM + 06 wrx flywheel) on my car, currently right around 400 whp / 400 ft-lbs. Surprisingly the oem clutch, with 51k on it, is still holding. I'm hoping it'll last until we get moved. Link to comment Share on other sites More sharing options...
mwiener2 Posted July 2, 2009 Author Share Posted July 2, 2009 Noticed something today. My ACT LWFW has a spacer ring on it. Wonder if I need this with the WRX flywheel? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
AKLGT Posted July 4, 2009 Share Posted July 4, 2009 will an 05 WRX fw work? or it has to be 06? Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
mwiener2 Posted July 4, 2009 Author Share Posted July 4, 2009 06+ only AFAIK My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
mwiener2 Posted July 6, 2009 Author Share Posted July 6, 2009 Spacer ring is to make the LWFW work on our cars. It gets tossed if you use a 06+ WRX FW. Now my next super sucky problem.... I cannot for the life of me get the old FW off the old shortblock. I have the proper torx+ bit and all it does it round out. Grrrrrr My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
mwiener2 Posted July 7, 2009 Author Share Posted July 7, 2009 OMG I hate the tech at the Subaru Dealership in Williamsport, PA. That's besides the fact I hate Williamsport in general. So the Torque spec on the flywheel bolts is 52FtLbs. I couldn't get them to budge with a 2ft breaker bar. So I went to home depot and got a 350FtLbs impact gun. Then all the Torx+ bolts stripped out. So then I used a rounded off bolt remover kit and was able to get them off..... but only after breaking the impact gun. Don't think they were at 52FtLbs. They owe me some bolts. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
lag Posted July 11, 2009 Share Posted July 11, 2009 Lightweight flywheel for daily/city driving is indeed a pain in the arse. If you are a SERIOUS racer then it's recommended, otherwise the 06 wrx part is probably the right choice. I am going to do the same setup (ACT HDMM + 06 wrx flywheel) on my car, currently right around 400 whp / 400 ft-lbs. Surprisingly the oem clutch, with 51k on it, is still holding. I'm hoping it'll last until we get moved. My stock clutch is slipping like hell, I'm searching now for what to replace it w/. example, 3rd gear ~3000rmps... mash gas... ZING... I'm going no where fast. So now I get to baby it until I get the bitch replaced. 53K miles, stock up until ~40K then just Cobb AP + Filter. The clutch was shit to start w/ though and should have replaced it under warranty... just did not want anyone, other than me, going into my car like that touching its fiddly bits. Link to comment Share on other sites More sharing options...
mwiener2 Posted July 11, 2009 Author Share Posted July 11, 2009 i have a LWFW for sale.... all you need is a pressure plate and a friction disc My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
itsme Posted July 12, 2009 Share Posted July 12, 2009 So how do you like the new setup compared the LWFW? Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
mwiener2 Posted July 12, 2009 Author Share Posted July 12, 2009 I dunno. It's not in the car yet. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
terrangama Posted July 12, 2009 Share Posted July 12, 2009 im curious too. I bought my car with a LWFW and it is the only car I have ever driven stick. When i switched clutches i got a LWFW again. Wondering if there is a big difference, cuz Los Angeles is a bitch! Link to comment Share on other sites More sharing options...
f1anatic Posted August 25, 2009 Share Posted August 25, 2009 I got used to it after a while; you'd love it in acceleration but it takes some getting used to - in order to keep the revs up. I would say it revs up 50% quicker. (ACT HDMM and ACT Streetlite FW). Link to comment Share on other sites More sharing options...
mwiener2 Posted August 25, 2009 Author Share Posted August 25, 2009 I like the heavier FW much better My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
qikslvr Posted August 25, 2009 Share Posted August 25, 2009 I'm ditching my SPEC LWFW when the clutch goes again. I didn't feel any real gain from it, but I do feel all the vibration; and hear all the noise from the transmission. Let's kick this pig! Link to comment Share on other sites More sharing options...
