David Francis Posted June 1, 2009 Share Posted June 1, 2009 No Manual Three things I cannot figure out. Can anyone "shine any light"? Under bumper front lights. There are 2 light on either side. I cannot figure out when or how to turn on the outer lights. The inner ones work from a switch on the rh side of the dash board. There is a switch between the seats with a symbol that looks like a heated rear window and a wiper. There is already a swith on the lh side of the dashboard that looks like a heated rear window? There is a strange plastic fitting that swings up on the lh side of the gear selector. I cannot figure out what its purpose in life might ever be? Link to comment Share on other sites More sharing options...
ehsnils Posted June 1, 2009 Share Posted June 1, 2009 1. Post some pictures of the lights, that may give an additional clue. 2. Heated wiper blade for the first switch. The second is likely to be the heated rear window, unless you also have a switch for that, then the switch is for the mirrors only. Later model has a combined rear window and mirror heating switch. 3. That may be a cover for the dual range lever that's on the MT wagon. Pics may help. Link to comment Share on other sites More sharing options...
David Francis Posted June 4, 2009 Author Share Posted June 4, 2009 Finally found out how to get the photos in. I've put 4 in on the original post. Thanks David Link to comment Share on other sites More sharing options...
