burnout8488 Posted October 14, 2010 Share Posted October 14, 2010 http://www.subtle-solutions.com/product_info.php?products_id=109 Your lift kit has arrived sir. This is probably the most reliable way to get a little lift without messing with taller struts or springs. Link to comment Share on other sites More sharing options...
The Internet Posted October 14, 2010 Share Posted October 14, 2010 the outbacks are wider. Look at the pic of the red car above. Notice the fender flares. The camber geometry wont work well with your car. ps you should ALWAYS trust the internet Link to comment Share on other sites More sharing options...
burnout8488 Posted October 14, 2010 Share Posted October 14, 2010 the outbacks are wider. Look at the pic of the red car above. Notice the fender flares. The camber geometry wont work well with your car. ps you should ALWAYS trust the internet Yep, Outbacks have higher offset wheels to poke them out into the flares more. Link to comment Share on other sites More sharing options...
jedraz Posted October 14, 2010 Share Posted October 14, 2010 Just do the opposite of this. http://legacygt.com/forums/showthread.php/lgt-wagon-suspension-swapped-into-outback-xt-140548.html Link to comment Share on other sites More sharing options...
hollendtino Posted October 15, 2010 Share Posted October 15, 2010 Thanks burnout! Just what I am looking for. Link to comment Share on other sites More sharing options...
frank_ster Posted October 16, 2010 Share Posted October 16, 2010 i want to make some hydraulic doughnuts that i can place between the spring and the strut to be able to raise my car when i go offroading i hade a similar designe for work so just so happens i have parts to do this sort of thing ! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
IanB Posted October 16, 2010 Share Posted October 16, 2010 Yep, Outbacks have higher offset wheels to poke them out into the flares more. That would be lower offset would it not? How do Outbacks do with wheel bearings, everyone goes on about how they wear prematurely on the Legacies if you run low offset wheels. Link to comment Share on other sites More sharing options...
BAM Posted October 24, 2010 Share Posted October 24, 2010 Hi all, I have a 2005 Legacy GT and I want my car to have the same clearance as the car in this photo. What parts do I need to make this happen, and how much did it cost you? I live in Washington and we are expecting a nasty Winter. Any suggestions are greatly appreciated! http://deexboy.com/albums/album26/11_G.sized.jpg Link to comment Share on other sites More sharing options...
DeltaSniper Posted October 24, 2010 Share Posted October 24, 2010 Thats an Outback sedan... read the discussion its harder to do than you think. Link to comment Share on other sites More sharing options...
