scoobydoobie Posted May 29, 2009 Share Posted May 29, 2009 I know most people data log in 3rd, but is there a reason you cannot use a 2nd gear pull for map tweaking purposes? I understand that you will not see peak boost in 2nd. Reason I ask is because around here, there aren't really any good safe spots for me to do a 3rd gear pull from 2K to redline. And I don't track the car. Other than boost, would any other parameters be affected by using 2nd rather than 3rd? Thanks. Link to comment Share on other sites More sharing options...
nka Posted May 29, 2009 Share Posted May 29, 2009 engine load will be affected and RPM will raise too fast to have a good dataloggin. For myself, I've found a no-to-used flat highway place Link to comment Share on other sites More sharing options...
scoobydoobie Posted May 31, 2009 Author Share Posted May 31, 2009 alright thanks. So I guess 2nd is a no-go for data logging? Link to comment Share on other sites More sharing options...
Richard B. Posted May 31, 2009 Share Posted May 31, 2009 I know most people data log in 3rd, but is there a reason you cannot use a 2nd gear pull for map tweaking purposes? I understand that you will not see peak boost in 2nd. Reason I ask is because around here, there aren't really any good safe spots for me to do a 3rd gear pull from 2K to redline. And I don't track the car. Other than boost, would any other parameters be affected by using 2nd rather than 3rd? Thanks. i did a 2ng gear acclereation log from down low to 60+. you WILL hit peak boost. at least i do. 16+psi. its datalog number 8 in the rallitek forum. the rest i dunno. Link to comment Share on other sites More sharing options...
scoobydoobie Posted June 2, 2009 Author Share Posted June 2, 2009 any experts want to chime in here? Can I datalog in second gear? Why or why not? Link to comment Share on other sites More sharing options...
NSFW Posted June 6, 2009 Share Posted June 6, 2009 Logging in 2nd will get you some good data, but not enough. Then again, the same is true for logging in 3rd. Doing a 3rd gear WOT pull is great for sanity checking (it's popular for good reasons), but it still only covers a portion of each relevant table. To cover everything, you really need to log in all gears anyway, and at various throttle openings. Link to comment Share on other sites More sharing options...
jim1969 Posted June 6, 2009 Share Posted June 6, 2009 why not 4th gear esp. on the 05-06 LGT 5EAT? The gear ratio is 1:1 in that model. Link to comment Share on other sites More sharing options...
scoobydoobie Posted June 6, 2009 Author Share Posted June 6, 2009 Logging in 2nd will get you some good data, but not enough. Then again, the same is true for logging in 3rd. Doing a 3rd gear WOT pull is great for sanity checking (it's popular for good reasons), but it still only covers a portion of each relevant table. To cover everything, you really need to log in all gears anyway, and at various throttle openings. thanks for the response. Link to comment Share on other sites More sharing options...
dwolson2 Posted June 8, 2009 Share Posted June 8, 2009 why not 4th gear esp. on the 05-06 LGT 5EAT? The gear ratio is 1:1 in that model. I don't think I would want to even try a 4th gear, I did a 3rd gear(about 90 mph) and wasn't sure I was going to have enough road. But I was in LA.... Link to comment Share on other sites More sharing options...
jim1969 Posted June 8, 2009 Share Posted June 8, 2009 I mean on the dyno. Link to comment Share on other sites More sharing options...
dwolson2 Posted June 9, 2009 Share Posted June 9, 2009 "dyno" huh... yea I was on a "dyno" in LA, er thats what I meant Link to comment Share on other sites More sharing options...
