dowright82 Posted May 14, 2009 Share Posted May 14, 2009 Tried to log MICKEYD Approved parameters here - but didn't see KNOCK SUM anywhere. Looks good to me except one knock around 6800-7000 rpms - but it wasn't repeatable . . . tried several times to reproduce it. Thoughts guys?? PS: This is MICKEYD's Stage 2 2005 MT Map . . . . I used it but at this point i've reduced WG Duty Cycle INITIAL and MAX by 7 degrees. Working my way slowly to the full blown MAP atm pressure here is about 14.2 and I'm running 93 OCTANE fuel.romraiderlog_20090513_202616.csvromraiderlog_20090513_202705.csvromraiderlog_20090513_202840.csv Link to comment Share on other sites More sharing options...
rtbrjason Posted May 14, 2009 Share Posted May 14, 2009 You should probably add requested torque, or throttle position to the logs. Link to comment Share on other sites More sharing options...
dowright82 Posted May 14, 2009 Author Share Posted May 14, 2009 Good call, I'll log some more - thought it might be somewhat understood that RPMS rising quickly = full throttle. all I really did IS full throttle or NO throttle. Will log some more tonight and in the morning . . . nothing screams STOP that I don't see though, right? Link to comment Share on other sites More sharing options...
dowright82 Posted May 14, 2009 Author Share Posted May 14, 2009 Phenomenal Map - - - Much smoother than my STAGE 1 Map - let alone my Stock Map . . . Very linear throttle response . . PROPS MICKEYD! Oh yeah - and since this is a 2005 map - My cruise won't work anymore . . . any help MickeyD?? Link to comment Share on other sites More sharing options...
Legend Posted May 14, 2009 Share Posted May 14, 2009 Oh yeah - and since this is a 2005 map - My cruise won't work anymore . . . any help MickeyD?? You need to put the right map on your car. Don't put an '05 map on an '06. Your cruise control will not work since some '05's have the neutral position switch wired differentlly. If you can't find your specific rom (mickeyd stage 2), then you'll have to build one from a copy of your stock rom by copying over tables. My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
dowright82 Posted May 14, 2009 Author Share Posted May 14, 2009 Yep, thats what I'm gonna do. Thanks a bunch!! I could have sworn I read somewhere on ROMRAIDER that this map was 2006 model safe! oh well - - Link to comment Share on other sites More sharing options...
rtbrjason Posted May 14, 2009 Share Posted May 14, 2009 Yep, thats what I'm gonna do. Thanks a bunch!! I could have sworn I read somewhere on ROMRAIDER that this map was 2006 model safe! oh well - - He said: "This map can be used on other 05-06 LGTs but you will need to copy all the tables over to your rom." Link to comment Share on other sites More sharing options...
dowright82 Posted May 14, 2009 Author Share Posted May 14, 2009 Yeah, I'm obviously wrong. Sorry guys - we can close this one! Link to comment Share on other sites More sharing options...
dowright82 Posted May 15, 2009 Author Share Posted May 15, 2009 So I finally got some decent logs . . . with a fixed 2006 map . . . oh the silly things we do sometimes . . . Anyway - attached are some short logs . . 1) WOT 2) Driving Around Town 3)strange one where I had some knock under VERY little load. I absolutely LOVE the map though - but I'm also getting lots of POSITIVE knock correction advance . . . I'm such a noob.aroundtown06.csvlowloadknock06.csvwotstg206log1.csv Link to comment Share on other sites More sharing options...
Infamous1 Posted May 16, 2009 Share Posted May 16, 2009 You started your WOT run way too late, it needs to be done at 2K and should be taken to atleast 6k rpms. Either way you have some knock in that log as well. Link to comment Share on other sites More sharing options...
mickeyd2005 Posted May 16, 2009 Share Posted May 16, 2009 So I finally got some decent logs . . . with a fixed 2006 map . . . oh the silly things we do sometimes . . . Anyway - attached are some short logs . . 1) WOT 2) Driving Around Town 3)strange one where I had some knock under VERY little load. I absolutely LOVE the map though - but I'm also getting lots of POSITIVE knock correction advance . . . I'm such a noob. You need to log the same parameters that DEAKS2 is logging. You're getting some tip-in knock as the throttle is opening. Link to comment Share on other sites More sharing options...
