Boost Gauge Illumination Problem
ERLoft
So, installed a new Defi Racer boost gauge this weekend. Went pretty well - it was replacing a Prosport gauge, so it was pretty straightforward. However, same as my Prosport gauge, I wasn't able to find a wire that supplied +12v when the headlights/parking lights are on. Seems that the wires coming off the combination switch (light/turn signal stalk) are +12v when the lights are off, the go to +0v when they're on. I was able to find two wires that are +12v when the low beams are on, but they go to +0v when the high beams are on.
I know most of you have been able to use the clock illumination wire, but as I have a Spec B with nav, I don't have the clock. I would imagine that the wiring is still present though, so can someone post up a picture of what the connector to the back of the clock looks like so I can see if it's present in my car?
Alternately, if anyone knows of a specific wire that's +12v when the parking lights/low beams/high beams are on, I'd be happy to find it on my car!
Thanks!
2013 S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s -
[sIGPIC][/sIGPIC]
C'mon now - no one has a picture of what the power connector for your clock/trip computer looks like?
[sIGPIC][/sIGPIC]
I don't have a cubby. Spec B's have the satnav systems instead. That's why I'm asking for help...
[sIGPIC][/sIGPIC]
Might have been a thought. I ended up removing the nav screen and using my multimeter to figure out which wire controlled the dimming there and tapped off of that. Works fine now. :)
[sIGPIC][/sIGPIC]
