Colourfyre Posted May 8, 2009 Share Posted May 8, 2009 Hi, my window wipers are just all ova the place. They park in random positions all the time (on every stroke). Its really annoying because if they park high up the windscreen, on the next stroke they wipe outside the windscreen. Has anyone got any suggestions to fix this annoying problem? Thanks CF Link to comment Share on other sites More sharing options...
eekay Posted May 8, 2009 Share Posted May 8, 2009 In all honesty, this sounds like loose wiper nuts... Just to be sure, grab a wrench (Whatever type you want, any will work as long as it is the correct size) and make sure they are tight. Of course, position them correctly before you tighten them. Also, check to see if the little "slider" bolts that hold the blades are stripped in any way. My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
gathermewool Posted May 8, 2009 Share Posted May 8, 2009 A.W.O.L.: Absent With Out Leave '15 FB25 Magnatec 0W-20 + FU filter (70,517 miles) RSB, Fr. Strut Bar, Tint, STI BBS, LED er'where Link to comment Share on other sites More sharing options...
Colourfyre Posted May 8, 2009 Author Share Posted May 8, 2009 lol, awol was just the first expression that came to mind:) I have checked that the wipers are tight on there shafts and that the teeth that prevent them turning all over the place are not damaged. If i take both blades off the windscreen there is about 10 degrees of completely free turning, so they sort of flap round a bit. Its like the motor/gearbox is worn badly or something. I have already tried moving them on the toothed shafts (taking them off and repositioning) but the park position is quite random, so most of the time its off but there is the odd time that they work correctly. Thanks for the suggestions CF Link to comment Share on other sites More sharing options...
eekay Posted May 8, 2009 Share Posted May 8, 2009 I just came across this post that might be of some help... http://www.handymanwire.com/ubbthreads/showflat.php?Cat=0&Number=795609&Main=794530 And also this... http://www.subaruforester.org/vbulletin/f80/windshield-wiper-clunk-2976/ My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
Colourfyre Posted May 9, 2009 Author Share Posted May 9, 2009 Thanks eekay, It sounds like some of the bushes have worn out so i guess i will b pulling the whole thing apart. Thanks again for pointing me in the right direction. Link to comment Share on other sites More sharing options...
jonklein611 Posted May 11, 2009 Share Posted May 11, 2009 That happened to my rear wiper, the plastic gearbox stripped out. Link to comment Share on other sites More sharing options...
eekay Posted May 11, 2009 Share Posted May 11, 2009 Thanks eekay, It sounds like some of the bushes have worn out so i guess i will b pulling the whole thing apart. Thanks again for pointing me in the right direction. Not a problem at all. Let us know if that was indeed the problem and what you ended up doing to fix it. My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
