Stock size or...
RJS5689
The factory size on the Spec.B is 215/45/18. I've never had a vehicle with this size before until now. I normally match a 45 sidewall to a 17 and a 40 to an 18. I was running 225/40/18s on my last vehicle. So here are my questions:
1. Should I keep the stock size, or should I drop down to a 40 sidewall to help stiffness in corners, or will it not be too noticeable?
2. I was also thinking of going slightly wider to a 225 tire. Again, are the benefits going to be noticeable, or not?
Obviously the tire I choose will be based on the size, as they aren't all available in those sizes. The Yokohama S.Drive has caught my eye for right now though, and those would be a 215/40/18.
