Yojimbo_g Posted May 6, 2009 Share Posted May 6, 2009 As the title says. Will 06 Baja wheels (16") work with an 06 Outback 2.5i ? They're basically the same car right? I'd like to put 225/60/16's on 'em for more sidewall. If I can't get those rims (they seem to be over priced, or sold out wherever I look) I'll just slap on a set of 16" Forester steelies (and paint 'em charcoal). And on that note, will the standard 16x6.5 (48 off) 5 spoke steelies from a Forester take a 225/60/16 tire (specifically a Goodyear triple tread)? A Subaru parts site I found says these take 215/60/16. Thanks! Link to comment Share on other sites More sharing options...
OhBe1 Posted May 11, 2009 Share Posted May 11, 2009 Well, the Baja was based on the 2nd-gen Outback (2000-2004). Different chassis that the 2005+ Outback. Probably not enough to make a difference, but I'd check the offset. . 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
