phenryiv1 Posted May 6, 2009 Share Posted May 6, 2009 If I grab an RSB from a SpecB, what do I need, in addition to the bar itself? Endlinks? Brackets? Bushings? Also, is the SpecB bar any different frmo the LGT bar? Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
mwiener2 Posted May 6, 2009 Share Posted May 6, 2009 AFAIK, the LGT and SpecB have the same RSB. Go JDM, yo My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
phenryiv1 Posted May 6, 2009 Author Share Posted May 6, 2009 $40 shipped for an LGT/SpecB is good enough for me... Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
Underdog Posted May 6, 2009 Share Posted May 6, 2009 The GT/Spec.B RSB is 16mm, only 1mm larger than the 2.5i bar, and still vastly undersized for the weight of the car. I can't imagine the difference in body roll being worth even $40... but hey, it's your cash. The Crimson Dynamo Link to comment Share on other sites More sharing options...
phenryiv1 Posted May 6, 2009 Author Share Posted May 6, 2009 I thought it was 19mm, for some reason. Nevermind. Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
shtbxr22 Posted May 9, 2009 Share Posted May 9, 2009 pretty sure JDM is 19mm. if your going from 2.5i to gt or spec B, you should just bolt it in. 1 mm won't affect the bushings, and the links should be the same. originally I went from a 15 to 16 without needing anything else. now at 25mm Link to comment Share on other sites More sharing options...
BrownBoy Posted May 9, 2009 Share Posted May 9, 2009 JDM originated at 20mm; they made the bar smaller over the years. Link to comment Share on other sites More sharing options...
OhBe1 Posted May 10, 2009 Share Posted May 10, 2009 But the JDM 20mm is hollow; I think about equivalent of 18mm solid, just lighter. And the 1mm difference getween 15 & 16 should be noticeable (did that before going to the JDM 20). But then ours is an Outback. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
phenryiv1 Posted May 11, 2009 Author Share Posted May 11, 2009 pretty sure JDM is 19mm. if your going from 2.5i to gt or spec B, you should just bolt it in. 1 mm won't affect the bushings, and the links should be the same. originally I went from a 15 to 16 without needing anything else. now at 25mm Was the 15-16MM increase noticable on the 2.5i? Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
shtbxr22 Posted May 11, 2009 Share Posted May 11, 2009 very slight. sometimes I thought it was like a placebo. 25mm FTW!!! Link to comment Share on other sites More sharing options...
THE RZA Posted May 12, 2009 Share Posted May 12, 2009 hah, i went from 16 to 22/19mm such a big differance Link to comment Share on other sites More sharing options...
blaze741 Posted June 3, 2010 Share Posted June 3, 2010 did you notice any difference with the RSB on? I'm debating on swapping my 2.5i RSB with a GT one as you can get them for next to nothing. How was the install? Bolt off and bolt new one on correct? no need to jack car up? Link to comment Share on other sites More sharing options...
phenryiv1 Posted June 3, 2010 Author Share Posted June 3, 2010 Holy thread ressurection... As for the benefits, there was a slight improvement in perceived feel, but nothing that I could qauntify, and it may have been purely a placebo effect. I did this mod (for the 16mm LGT/SpecB bar) this past fall. The install was easy- I might have had to remove one wheel (maybe both) to do it properly- I can't remember. I installed it when I was rotating tires anyway. Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
blaze741 Posted June 3, 2010 Share Posted June 3, 2010 thanks for the quick reply. i didn't want to start a new thread on past discuss topics. =] i'm debating on just manning up and getting a thicker bar. It seems like I won't feel any difference from such a slight upgrade. Link to comment Share on other sites More sharing options...
mwiener2 Posted June 3, 2010 Share Posted June 3, 2010 Jdm!!!! My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
phenryiv1 Posted June 3, 2010 Author Share Posted June 3, 2010 Jdm!!!! I have to say that this may be the way to go. This, or RalliTek F&R, as they make the only F bar for the 2.5i. Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
AKLGT Posted June 3, 2010 Share Posted June 3, 2010 22mm RSB+ or else! and yes, RSB makes a huge difference! Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
IanB Posted June 3, 2010 Share Posted June 3, 2010 I just went from 15mm to 21mm solid (Cusco), pretty big difference. If you upgrade the RSB make sure you get some mount reinforcements. I don't think I'd bother with the 16mm, go big or go home. Link to comment Share on other sites More sharing options...
THE RZA Posted June 3, 2010 Share Posted June 3, 2010 i remember shtbxr talking about how he fit a tribeca fsb on his 2.5i when he had it, pm him about doing that i guess Link to comment Share on other sites More sharing options...
mwiener2 Posted June 3, 2010 Share Posted June 3, 2010 anything that fits a LGT should fit a 2.5i My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
N.sane Posted June 3, 2010 Share Posted June 3, 2010 anything that fits a LGT should fit a 2.5i Except for the front sway or front lower arm braces. Link to comment Share on other sites More sharing options...
mwiener2 Posted June 4, 2010 Share Posted June 4, 2010 According to my 2005 service manual, there is no difference between the suspension on different trims. I don't see why there would be. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
N.sane Posted June 4, 2010 Share Posted June 4, 2010 It's been discussed before, and that's why Rallitek made a non-turbo specific FSB. Something to do with the exhaust/header location being in the way. It may not apply to 05 since it still had UEL, but 06-09 for sure. You can see the difference in the following links, 1st link is non-turbo: http://www.rallitek.com/rafrswbar08i.html http://www.rallitek.com/rafrswbar20w.html Link to comment Share on other sites More sharing options...
mwiener2 Posted June 4, 2010 Share Posted June 4, 2010 O the exhaust is in the way notch it My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Subie2.5i Posted June 4, 2010 Share Posted June 4, 2010 I have the perrin sway for the lgt on my 2.5i all I had to do was take the top part of the shield from the midpipe and there is no rubbing. Link to comment Share on other sites More sharing options...
