Stuttering/Stalling Problem. Any Ideas?
Short synopsis: Car has 225k miles. 1998 Subaru Legacy Outback Limited. This winter I was waiting outside when the engine started surging - almost stalling then kicking back up, and it got worse and then stalled in a minute. Started it up and it did it again, and then it was fine. Next day, pulled out of a gas station, went to turn the wheel and found the engine had stalled. Seemed to only happen when idling - in fact, that was the issue. Anyway over the past two or three months its gotten worse to the point where now the car is constantly screwed up - constantly surging/stalling. Driving it it feels sick - like a half power, and it will occasionally stall completely. Issue gets worse if you let it sit idling for a minute or two. No CEL has come on in three months of stalling and countless times of ALMOST stalling and seeming misfires while driving. Here's a video I took of the issue (at night) but if you watch the first two minutes you can hear the problem quite clearly. Any suggestions as to what it could be?
[ame=http://www.youtube.com/watch?v=eG3F5Yzt7YU&fmt=18]YouTube - Car Troubles[/ame]
My '07 stutters when the gas cap isn't on tight. (Even when I think I've cranked it on enough...)
Maybe try a new gas cap if you've tested/replaced all of the other common causes. (Spark plugs & wires, fuel filter, etc.)
