spec.b Posted May 5, 2009 Share Posted May 5, 2009 as the title suggests, has anyone been able to mount v3's on a leg?I'll get the v2's if I have to, but it would be sweet to have rebound and damper control... Link to comment Share on other sites More sharing options...
slimjoe Posted May 5, 2009 Share Posted May 5, 2009 There was some talk of the V3's some time ago but it kind of died off. http://www.legacygt.com/forums/showthread.php?t=98227 Link to comment Share on other sites More sharing options...
icelatte Posted May 7, 2009 Share Posted May 7, 2009 Unless you're gonna spend track time to sort it all out, get the V2. I have V3 on my 911 and there's probably too much to tweak on the track between tire pressures, alignment, corner balance, then add in damper adjustments. The V3 adjustments are only for slow speed damper control. The high speed control (such as road cracks, speed bumps) are set by the factory anyway. Link to comment Share on other sites More sharing options...
spec.b Posted May 7, 2009 Author Share Posted May 7, 2009 thanks for the info... I was planning on using these for auto-x setup. I am in the process of designing a new rotated twinscroll turbo setup at the moment. Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted May 7, 2009 Share Posted May 7, 2009 The V3 adjustments are only for slow speed damper control. The high speed control (such as road cracks, speed bumps) are set by the factory anyway. other way around. LOW speed piston movement is on the highway. High speed piston movement is the FAST , QUIK jolts like expansion joints and or bouncing off of curbing at the track. Compression yes is preset from the factory in the high speed range but you are influencing the low speed compression. REBOUND is fully adjustable. At any rate we are alreayd working with KW of Germany on this for the Legacy. I will have a prototype that I will install on my car( unless we find a local) to test. Myles Link to comment Share on other sites More sharing options...
icelatte Posted May 7, 2009 Share Posted May 7, 2009 other way around. LOW speed piston movement is on the highway. High speed piston movement is the FAST , QUIK jolts like expansion joints and or bouncing off of curbing at the track. Compression yes is preset from the factory in the high speed range but you are influencing the low speed compression. REBOUND is fully adjustable. At any rate we are alreayd working with KW of Germany on this for the Legacy. I will have a prototype that I will install on my car( unless we find a local) to test. Myles I thought that's what I said. Anyway, good luck with the prototyping and I hope you convince KW to make the rebound adjustment more user friendly than I've found on the Porsche. Link to comment Share on other sites More sharing options...
spec.b Posted May 7, 2009 Author Share Posted May 7, 2009 any chance I can get in on the prototype action??? willing to pay for a set as long as they have the correct mounts for our b.spec tophats, and are offset spring rates (I prefer stiffer springs in the rear) Link to comment Share on other sites More sharing options...
spec.b Posted May 8, 2009 Author Share Posted May 8, 2009 BTW, Myles, what's the difference between your "tarmac 1" and the kw2's??? I really need a set of coils asap... Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted May 8, 2009 Share Posted May 8, 2009 I thought that's what I said. Anyway, good luck with the prototyping and I hope you convince KW to make the rebound adjustment more user friendly than I've found on the Porsche. Yeah it will be on top like the T1's are..BUT the compression will be on the bottom in the back, so very standard. Myles Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted May 8, 2009 Share Posted May 8, 2009 BTW, Myles, what's the difference between your "tarmac 1" and the kw2's??? I really need a set of coils asap... Valving is tweaked and we use the KW higher quality race springs that are more linear for more travel. Ordered now be here in 2-3 weeks. Myles Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted May 8, 2009 Share Posted May 8, 2009 any chance I can get in on the prototype action??? willing to pay for a set as long as they have the correct mounts for our b.spec tophats, and are offset spring rates (I prefer stiffer springs in the rear) Call in MOnday and I will add you to the list. Once this is up and running we will be fine. Its not a matter of "will they" its more so I just need to do the leg work( no pun) and make it happen. Myles Link to comment Share on other sites More sharing options...
camber Posted May 8, 2009 Share Posted May 8, 2009 Crap... I was just about to pull the trigger on AST's... Any guesstimate on price? Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted May 8, 2009 Share Posted May 8, 2009 Crap... I was just about to pull the trigger on AST's... Any guesstimate on price? Not yet, but will know soon. We are an AST dealer also....FWIW. Myles Link to comment Share on other sites More sharing options...
