puravidaa Posted May 4, 2009 Share Posted May 4, 2009 Get P1100 Code - Starter Switch Circuit Malfunction. Anybody have an idea where to proceed from here??? thanks Link to comment Share on other sites More sharing options...
ehsnils Posted May 5, 2009 Share Posted May 5, 2009 Does the car fail to start? Check the fuse box under the hood - especially any relay related to the starter switch. It may of course also be the switch itself. Link to comment Share on other sites More sharing options...
puravidaa Posted May 5, 2009 Author Share Posted May 5, 2009 Thanks for reply. Starter turns over fine. Car started today, but it did not other day (starter still turning over fine) If it turns over fine, what part of starter switch would keep it from starting?? Link to comment Share on other sites More sharing options...
ehsnils Posted May 5, 2009 Share Posted May 5, 2009 There are several items on the way, usually an interlocking relay and a contact at the clutch - or a contact at the gear selector for AT vehicles. The switch at the key can also be the problem. I don't have the wiring diagram at hand, but it seems like you have a bad connection somewhere, which can be tricky to find but not too hard to fix when you have found it. Link to comment Share on other sites More sharing options...
puravidaa Posted May 5, 2009 Author Share Posted May 5, 2009 Thanks will try to chase it down Link to comment Share on other sites More sharing options...
