Mixing Different Oil Brands
This may sound like a weird/dumb question but here goes.
Is it ok to mix types of oil (not grades)? Here's the situation since our car takes a little over 4 quarts of oil for a change I have about 5 or 6 more than half full quarts of oil. It's all 5w30 but it's different brands. I tend to buy what's on sale at the time. It's mostly synthetic blend, but a couple are full synthetic and one is Dino oil think, some is from previous Impreza and Wrangler changes.
I figure oil is oil is oil... you truly don't get it all out when change it anyway, unless you do a flush, so your really mixing oil anyway. I've been hesitant to do this, not sure why, so just wanted to get everyone's $.02
Please don't turn this into a thread about how I should use a certain oil brand and should'nt buy what's on sale. I stick with quality oil (Castrol, Pennzoil, Valvoline) but if Advance is running one cheaper, I'm gonna go with it.
Thanks for your input!!
I wouldn't do it. While I doubt you will see any problems, different oils have different additives packages they may or may not mix well. I'm always hesitant to even top off with a different oil even though I know it's not going to matter. I certainly couldn't imagine using half of 5 or 6 different kinds though.
As far as I know there shouldn't be any problems mixing oils, and I think that's one of the requirements on oil manufacturers to make sure that there aren't any additives that can have ill effects when intermixing.
Since an oil change never completely replaces all the oil in the engine this is actually an important factor.
But that said - it would be good to keep to one brand of oil and not intentionally mix oils unless you have a good reason to do it.
And also keep in mind that a turbo engine is more sensitive since the turbo can get very hot, so reserve the mixed oils for some naturally aspirated engine. Maybe it's time to take care of the lawnmower?
And considering that the turbo gets hot - a good idea would be to go for synthetic since that kind of oil generally is more stable while dino oil is a mix of hydrocarbons where some changes easier than others and can therefore easier build coke residue in the turbo when it gets hot.
Wow another thread like this.
IMO you can mix synthetic oils.
Personally I wouldn't waste the money. I have used them in the past but now use Dino oil, whatever is on sale at Walmart 5w30 or 10w30 depends on summer or winter. I have no issues from mixing brands or weight's in the almost 40 years that I have been doing my own oil changes. My 05gt wagon runs fine with 106,800 miles. Cobb AP stage 1 93 octane since about 8,000 miles.
Engine Build - Click Here
Another thread like this??? I tried searching and had no luck.... I don't find the search feature very useful IMO....
Thanks for the responses. As for going straight synthetic, my Subaru dealer said Subaru put out a publication NOT to use full synthetic as it is too thin and the engine consumes it quickly. Not sure how a synthetic is thinner than a comparable DINO of equal weight???? They use a blend when they do changes.
not to doubt you RAO, but where have you read this? I'm just curious to read the reasoning behind this, I have my own theories as to why it would be bad, and obviously there are a few on here......
Looks like my Wheel Horse might be getting a well deserved oil change with some quality oil :rolleyes:
Try this link and linked pages: http://legacygt.com/forums/showthread.php?p=1664482#post1664482
Personally I avoid Dino oil.
I read it on http://www.legaccygt.com.
Once you get the different brands of oil mixing together there is no telling what the molecules will do - you are likely to get either very large ones that will block all of the engine passages or very small ones that will leak, either way it is bad.
^lol Aren't you supposed to turn on sarcasm <sarcasm> and turn it off </sarcasm> or have you given up on oil threads. heh heh heh.... oh nevermind, I just read the disclaimer!
