zvir Posted April 28, 2009 Share Posted April 28, 2009 For the last three years My car (2000 GX sedan mt) had this clutch pedal squeakFinally solved. I have lubricated the pedal area- no results.Tried to lubricate master cylinder rod-no result.Disconnected the slave cylinder- still this annoying noise. so it is not the clutch . anyway I have lubricated to littele rod from the slave cylinder.it is not from switches on the pedal (as with US spec cars). And today I found. It is the hill holder PHV (Pressure hold valve) area.It is connected with a cable from the clutch pedal.5 seconds of WD40 on the little assembly , located under the brake booster (LHD car) And that what solved all the squeak Link to comment Share on other sites More sharing options...
