Jordan Posted April 27, 2009 Share Posted April 27, 2009 Wow its hitting the high 90's here in northern virginia and my car is pulling like it did when it was stock (My car is stg2 ofts). Is this the placebo effect or is this hot intake charge really cutting my power noticibly. Even further entising me to consider a turbo swap with meth. My car was super quick when it was in the 30's but damn this is ganna be a boring summer for driving if I stay stock turbo/ic and the weather picks up. How much will a fmic + cai remidy this probly without having to swap turbo. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 27, 2009 Share Posted April 27, 2009 The front mount will help the most. I don't think anybody will have exact numbers for you. I know there are formula's that will give you a ball park power gain per decrease in air temp. But do it more for the added power rather getting caught up in the numbers. My son called me once when he was driving our Civic with a big FMIC and the intake air temp was down below 100F the outside air temp was in the 90's. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rao Posted April 27, 2009 Share Posted April 27, 2009 What you want is water injection. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
05GT Guru Posted April 27, 2009 Share Posted April 27, 2009 What you need is a motorcycle Link to comment Share on other sites More sharing options...
Stang70Fastback Posted April 27, 2009 Share Posted April 27, 2009 I like the heat. I can get a few extra minutes of runtime before my car starts stalling (at least 5 minutes now!) Link to comment Share on other sites More sharing options...
BAC5.2 Posted April 27, 2009 Share Posted April 27, 2009 Temp increase is roughly linear across a turbo. An increase of 1 degree in ambient makes for an added degree of intake temp. So you, effectively, increased turbine outlet temp 60 degrees. A FMIC will have enough thermal mass that you'll likely be able to counter the increased ambient temp. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
