c-lo Posted April 26, 2009 Share Posted April 26, 2009 Piece of metal punctured my back driverside tire. puncture is on the inside of the last tread before the sidewall. make sense? Sears wouldn't patch it because "we are sears, and we don't patch z rated tires". Pep boys did but explained that it would lose its "z" rating. Since I don't drive 100+ miles/hour I had it patched. any issues I should be looking at in the future or am I safe? 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
PeterJMC Posted April 26, 2009 Share Posted April 26, 2009 Goodyear patched my Z rated tires. I've had no problems at all Link to comment Share on other sites More sharing options...
RochNY91TSI Posted April 26, 2009 Share Posted April 26, 2009 It loses the Z rating b/c there's some damage to the integrity of the tire. Should still be fine for driving around on though. Did you actually have a plug put in, or a patch from the inside? Link to comment Share on other sites More sharing options...
cseagle08 Posted April 26, 2009 Share Posted April 26, 2009 Plug, I wouldn't trust that at speed, but I've had many a patch from the inside on Y rated rubber (186 mph+) done at Sears and at Discount Tire and taken it up to 140mph a few times and it held just fine. Link to comment Share on other sites More sharing options...
c-lo Posted April 27, 2009 Author Share Posted April 27, 2009 P- plugged or patched? looks like mine is plugged. sticky gooey stuff where the puncture was. Goodyear patched my Z rated tires. I've had no problems at all 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
PeterJMC Posted April 27, 2009 Share Posted April 27, 2009 Is it possible to plug AND patch? It's def plugged. There is a nice thin round chunk of rubber in there that wasn't part of the original tire. Link to comment Share on other sites More sharing options...
cseagle08 Posted April 27, 2009 Share Posted April 27, 2009 I don't think it's possible to use a separate plug and patch. the patch is really called a plug/patch, it has like a big nipple that goes thru the puncture. http://classic.artsautomotive.com/TirePatch.htm Link to comment Share on other sites More sharing options...
PeterJMC Posted April 27, 2009 Share Posted April 27, 2009 I don't think it's possible to use a separate plug and patch. the patch is really called a plug/patch, it has like a big nipple that goes thru the puncture. http://classic.artsautomotive.com/TirePatch.htm I think that's what they did Link to comment Share on other sites More sharing options...
c-lo Posted April 27, 2009 Author Share Posted April 27, 2009 considering I only waited 30-45min this is not what they did to mine. guess I'll call my mechanic tomorrow. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
