LGTspecB1657615261 Posted March 12, 2010 Share Posted March 12, 2010 They are +48. Wouldn't they be more apt to rub as the stick out farther than +44? [facepalm] You are correct. Link to comment Share on other sites More sharing options...
rnstein69 Posted March 12, 2010 Share Posted March 12, 2010 My wheels are +44 offset and 18 x 8.5 w/245/35/18 size tires. I had to roll the rears, fronts and add negative camber to the front to get it all to work without rubbing. I also am lowered to about a 1 finger gap all around on tein flex coilovers. Link to comment Share on other sites More sharing options...
rs6er Posted March 12, 2010 Share Posted March 12, 2010 [facepalm] You are correct. And wouldn't that make them more likely to rub? Link to comment Share on other sites More sharing options...
coldradio1 Posted March 12, 2010 Share Posted March 12, 2010 They are +48. Wouldn't they be more apt to rub as the stick out farther than +44? No. The lower the offset the more poke you get. Less offset = closer to fender. More offset = closer to the inside. Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted March 12, 2010 Share Posted March 12, 2010 http://www.tirerack.com/images/wheels/tech/offset.gif Link to comment Share on other sites More sharing options...
coldradio1 Posted March 13, 2010 Share Posted March 13, 2010 http://www.tirerack.com/images/wheels/tech/offset.gif I'm hoping your not trying to prove me wrong with this quote. Because this supports my previous statement. Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted March 13, 2010 Share Posted March 13, 2010 No you are correct - after I looked at the diagram I realized this, that is why I posted it. Sorry, I meant to put some text in that post! My logic went backwards there for a second. Link to comment Share on other sites More sharing options...
maddoc Posted March 15, 2010 Share Posted March 15, 2010 Thread bump again 255/35/18 on 18x8.5 +48 wheel and Koni + STi Pink springs....will it fit? I'm ONLY considering this size because there is a local guy selling 255/35/18 Star Specs for practically nothing and only 3k miles... Otherwise I would likely be going with 245s. I have 235/40/18 on the car right now, no rubbing, however there is a little stretch...I'd much rather a squarer sidewall Link to comment Share on other sites More sharing options...
whitetiger Posted March 18, 2010 Share Posted March 18, 2010 you may need +45 or alittle less for inboard clearance. a 5mm spacer would assist if you cant get a rim in that offset. 245 will definitly fit, but you will need a fender roll and a good amount of camber. Link to comment Share on other sites More sharing options...
wpgspecb Posted April 20, 2010 Share Posted April 20, 2010 http://legacygt.com/forums/showthread.php/velox-javlin-j-2-18x7-135930.html 235/40/18 on 18x7.5 wheels with +42 offset 2008 spec b rub on left rear with factory shock (40,000kms) no rub on right rear (new shock 5000km ago) Link to comment Share on other sites More sharing options...
maddoc Posted April 22, 2010 Share Posted April 22, 2010 you may need +45 or alittle less for inboard clearance. a 5mm spacer would assist if you cant get a rim in that offset. 245 will definitly fit, but you will need a fender roll and a good amount of camber. I'll check my clearance for 255s. I cant find many tires in 245/35/18 Link to comment Share on other sites More sharing options...
whitetiger Posted April 22, 2010 Share Posted April 22, 2010 kumho XS for 160ish a tire on tirerack.com in 245/35/18 Link to comment Share on other sites More sharing options...
speedfreek Posted April 25, 2010 Share Posted April 25, 2010 I am running 235's on My LGT with Tein springs and no rubbing issues. Link to comment Share on other sites More sharing options...
bigdadi Posted April 25, 2010 Share Posted April 25, 2010 Discount Tires recommends below ... for 2006 LGT Plus One http://www.discounttiredirect.com/images/kotspacer.gif215/40-18225/40-18235/35-18235/40-18 Link to comment Share on other sites More sharing options...
wpgspecb Posted April 25, 2010 Share Posted April 25, 2010 I am running 235's on My LGT with Tein springs and no rubbing issues. are your fenders rolled? do you have negative camber? Link to comment Share on other sites More sharing options...
Saul_Good Posted April 25, 2010 Share Posted April 25, 2010 I have 245/35/18 Federal 595 RSR on 18x8 SSR Comps. I had to a 3mm spacer to clear the inboard in the front. Other than that no issues. These tires are WIDE btw. Link to comment Share on other sites More sharing options...
wpgspecb Posted May 22, 2010 Share Posted May 22, 2010 I have 245/35/18 Federal 595 RSR on 18x8 SSR Comps. I had to a 3mm spacer to clear the inboard in the front. Other than that no issues. These tires are WIDE btw. what was the offset of those rims Link to comment Share on other sites More sharing options...
claudiablack Posted May 25, 2010 Share Posted May 25, 2010 I have found even less tires in this size compared to 235/40 also I believe that 35's are to thin(not width wise). Like i said im going to be getting g-forces 18X8.5 on 235/40R18 on stock suspension (as long as it doesn't look like a monster truck) and I'll tell you if they rub or not! Tinting Link to comment Share on other sites More sharing options...
cheryjones Posted May 26, 2010 Share Posted May 26, 2010 I really like the HM2's. Where did you get them from and how much did they cost ya? I plan on getting those also same size as you. Let me know im intrested. Tinting Link to comment Share on other sites More sharing options...
07wrxstage2 Posted December 13, 2015 Share Posted December 13, 2015 Bump for two questions. Think I'll have any rubbing with 18x8.5 +45mm wrapped in 235/40/18's? Currently lowered 1" in the front and .5" in the rear with -1.8 camber in the front. Suspension is konis, hr springs, whiteline com c tophats and 1/4" spacers in the rear. Might take the spacers off for a total of .75" drop in the rear. Think it will matter if I do as far as rubbing? Also on another note. Since I have the 5eat my invidia downpipe hangs pretty low to the ground even though im only lowered 1" in the front. I don't have any issue's except for when I visit my mom. She has these awful speed bumps. I currently run 17" wheels with 215/45/17. When I use the calculator thats a diameter of 24.6" and if I go with 235/40/18's it says that's a diameter of 25.4". So with .8" more diameter that would give me .4" more ground clearance to help with my issue correct? Here is a pic of my issue. Thanks for any help. http://i1082.photobucket.com/albums/j369/wrxsti4life/2F287ED0-554A-42B5-AF7C-BDB7C96851BF_zpsietynvb7.jpg You can see I'm not even that low. http://i1082.photobucket.com/albums/j369/wrxsti4life/8B205F98-C308-4D9A-BE51-BDF358B484B0_zps0fdadjky.jpg Alex D. JDM Prestige Motors alex@jdmprestigemotors.com Link to comment Share on other sites More sharing options...
Drift Motion Posted December 14, 2015 Share Posted December 14, 2015 sure you have more ground clearance, but your tires will be huge and you'll likely run into rubbing issue especially if the car is lowered. Learn how to drive with the mad JDM angle style to clear those bumps Link to comment Share on other sites More sharing options...
07wrxstage2 Posted December 14, 2015 Share Posted December 14, 2015 sure you have more ground clearance, but your tires will be huge and you'll likely run into rubbing issue especially if the car is lowered. Learn how to drive with the mad JDM angle style to clear those bumps Thanks, opinion noted on the first part. Suggestion on a different tire size or think I'll rub regardless? From what I've read on here most people say no issue on stock suspension. I didn't see anyone with a mild drop comment. As for the second part I'm sure you're just being funny but If not I'm pretty sure that would only help for anything from the front wheels to the front of the car from rubbing. Nothing behind such as my downpipe. Alex D. JDM Prestige Motors alex@jdmprestigemotors.com Link to comment Share on other sites More sharing options...
fantasyxiv Posted December 15, 2015 Share Posted December 15, 2015 Hi there mate, I have a 2010 LGT here in Australia, currently running Rota Gravel 18 X 8.5 + 44 with tyre size 245 45 18s. The wheels are slightly cambered however in Australia you cant legally have tyre poke outside your guards. I have several pictures on my profile. or view page 58: http://legacygt.com/forums/showthread.php/show-off-your-5th-gens-aftermarket-wheels-192431.html?p=5223776 Link to comment Share on other sites More sharing options...
Drift Motion Posted December 15, 2015 Share Posted December 15, 2015 see when you drive straight across the bump, pipe is very close to the bump. when you drive sideways, by the time one wheel crosses the bump, the other wheel will get onto the bump therefore creating more clearance. Link to comment Share on other sites More sharing options...
07wrxstage2 Posted December 15, 2015 Share Posted December 15, 2015 Hi there mate, I have a 2010 LGT here in Australia, currently running Rota Gravel 18 X 8.5 + 44 with tyre size 245 45 18s. The wheels are slightly cambered however in Australia you cant legally have tyre poke outside your guards. I have several pictures on my profile. or view page 58: http://legacygt.com/forums/showthread.php/show-off-your-5th-gens-aftermarket-wheels-192431.html?p=5223776 Thanks, but unfortunately that's not helpful to me as I have an 05 lgt. Looks good nonetheless. Alex D. JDM Prestige Motors alex@jdmprestigemotors.com Link to comment Share on other sites More sharing options...
