nm Posted April 25, 2009 Share Posted April 25, 2009 So after 6 track days and 1 year (about 25k mi) I need a new brake rotor. I'm getting some small amounts of cracking, and I'm not running them in another track day. I have the OEM rotor as it was the only thing I could find when i really really needed new rotors last time. I'm looking for blank (more pad wear and more cracking for more money, where do I sign?), 1 piece rotors (needed for AX classing) that maybe will last a bit longer. I run XP10s on the track (though I may go XP12 next time in the front) and HPS on the street. I've searched around, and I've heard some references to DBA 4000 blanks, but I can't find any. Any other suggestions? Otherwise, what's a decent "cheap" (relative to OEM) that will last a similar period. Link to comment Share on other sites More sharing options...
Mindspin311 Posted April 25, 2009 Share Posted April 25, 2009 I was really happy with Brembo stock replacements on my RX7. Ill probably do the same when the LGT needs new rotors. Seems Brembo only makes a blank for the rear of the GT. According to the following website http://www.buybrakes.com/brembo/am-apps-Subaru.html Link to comment Share on other sites More sharing options...
nm Posted April 25, 2009 Author Share Posted April 25, 2009 Brembo blanks were a first thought, but as you noted, they don't exist in the fronts. My rear rotors will last forever it seems anyhow. Link to comment Share on other sites More sharing options...
Mindspin311 Posted April 25, 2009 Share Posted April 25, 2009 According to DBA's site Front (4000 Series) - 42650 Rear (4000 Series) -4653 http://www.dba.com.au/2006/default.asp Link to comment Share on other sites More sharing options...
Mindspin311 Posted April 25, 2009 Share Posted April 25, 2009 Rally Sport Direct has them, quite pricey tho.. http://www.rallysportdirect.com/shop/brakes-brake-rotors-c-21_403_727_767.html Link to comment Share on other sites More sharing options...
nm Posted April 25, 2009 Author Share Posted April 25, 2009 Rally Sport Direct has them, quite pricey tho.. http://www.rallysportdirect.com/shop/brakes-brake-rotors-c-21_403_727_767.html Jeebus, I can get OEM rotors from fred beans for $100 less (with shipping). Are these going to last roughly twice as long? Honestly, 6 track days isn't horrible, I just always want more. What do you preopleb think of frozen rotors? I've heard of some good results on light cars (gutted civics) and no improvments on heavy cars (say an audi S4), so I lean toward not worth it, but opinions would be nice. Link to comment Share on other sites More sharing options...
Saul_Good Posted April 25, 2009 Share Posted April 25, 2009 Magnetic1 sells some really affordable blank type rotors. Check him out http://www.brakeswap.com Link to comment Share on other sites More sharing options...
05gtlimited300 Posted April 25, 2009 Share Posted April 25, 2009 napa 60 bucks Link to comment Share on other sites More sharing options...
Mindspin311 Posted April 25, 2009 Share Posted April 25, 2009 napa 60 bucks Untill you warp the hell out of them Link to comment Share on other sites More sharing options...
05gtlimited300 Posted April 25, 2009 Share Posted April 25, 2009 mine have been holding up fine and so have every other rotor ive got at napa Link to comment Share on other sites More sharing options...
caramall2 Posted April 25, 2009 Share Posted April 25, 2009 Magnetic1 sells some really affordable blank type rotors. Check him out www.brakeswap.com +1 one the brakeswap blanks ...sounds like what you're looking for...basically OEM but solid quality. I'm finding more "weekend warrior" track guys slap on good, but not terribly expensive, rotors as they know they're just going to go through them just like pads. I had DBA 4000 and they did fine too...reasonably priced, a slight bit better than stock. Now, I do believe curved vane 2-piece will give you better cooling, but, that's $600 out of your pocket for 2 rotors and $400 (+$50 for hardware) to replace the outer rings when you wear them out. How are your rotors "cracking"? (Also, have you measured the actual thickness of the rotor?) Why I ask, is mine got a bunch of surface cracks on them from the track. I was all worried, but one of the companies I buy brake supplies from say that can be fairly normal (not deep structural cracks, and not ones at say, the slots that are probably structural, but just surface "scally" type cracks). I think guys like Xenonk have gotten the same type of thing. Link to comment Share on other sites More sharing options...
aigochamaloh Posted April 26, 2009 Share Posted April 26, 2009 napa 60 bucks +1 Napa/Kragen/Autozone blanks work just fine for me. They held up fine on my MR2 with EBC Redstuff pads through multiple track days. I have a set of blanks for the Legacy sitting at home, will throw them on when school ends. Link to comment Share on other sites More sharing options...
magnetic1 Posted April 27, 2009 Share Posted April 27, 2009 +1 one the brakeswap blanks ...sounds like what you're looking for...basically OEM but solid quality. I'm finding more "weekend warrior" track guys slap on good, but not terribly expensive, rotors as they know they're just going to go through them just like pads. I had DBA 4000 and they did fine too...reasonably priced, a slight bit better than stock. Now, I do believe curved vane 2-piece will give you better cooling, but, that's $600 out of your pocket for 2 rotors and $400 (+$50 for hardware) to replace the outer rings when you wear them out. How are your rotors "cracking"? (Also, have you measured the actual thickness of the rotor?) Why I ask, is mine got a bunch of surface cracks on them from the track. I was all worried, but one of the companies I buy brake supplies from say that can be fairly normal (not deep structural cracks, and not ones at say, the slots that are probably structural, but just surface "scally" type cracks). I think guys like Xenonk have gotten the same type of thing. Any pics of the cracking? As Andrew says, it might be normal. We have the really generic non-coated blanks for even less. $150 shipped for the pair. Free Sonax Cleaner Deal http://www.brakeswap.com Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol... Great service. No bumping required ! Link to comment Share on other sites More sharing options...
nm Posted April 27, 2009 Author Share Posted April 27, 2009 Any pics of the cracking? As Andrew says, it might be normal. We have the really generic non-coated blanks for even less. $150 shipped for the pair. I gotta swap some wheels next weekend and I'll take some pictures. Link to comment Share on other sites More sharing options...
Paisan Posted April 28, 2009 Share Posted April 28, 2009 I cracked DBA4000s in 3 track days and about 5,000 street miles with HP+ pads. I've upgraded to Brembos but went with el-cheapo blanks for it and we'll see how they work out. $150 for the generic blanks shipped isn't bad. At our shop (AZP Installs) we stock for the legacies in the front Raybestos Rotors and so far they have been holding up well for our customers and they are in that $150 price range as well, so support the sponsors of the site and get the blanks from brakeswap.com. I will take some good pics of the DBA 4000s that I trashed out in 4 track days and post em up. -mike Link to comment Share on other sites More sharing options...
