Spec-B-JY Posted April 25, 2009 Share Posted April 25, 2009 All, I just installed an AVO air-filter and, upon turning the car back on, noticed the check engine light and cruise-control lights were on... Could you advise what my next step should be? I'm sorry if there is another post with this information. I did a search and the result was inconclusive. Link to comment Share on other sites More sharing options...
Jordan Posted April 25, 2009 Share Posted April 25, 2009 Did you accidentiley disconnect the MAF sensor on top of the airbox? If not maybe you put the filter in backwards it fits both ways. Link to comment Share on other sites More sharing options...
Spec-B-JY Posted April 25, 2009 Author Share Posted April 25, 2009 yes, i disconnected it. that must be it, [noob here]... how do I turn them off? or should I just wait since I have to go back to the dealer once my replacement stock-CD player arrives... Link to comment Share on other sites More sharing options...
FrozenNorthLGT Posted April 25, 2009 Share Posted April 25, 2009 Youll have to wait to get the lights shut off. Unless you have a friend that works at advance auto or autozone. They both have computers for checking the lights, and the same computers can erase them, but I don't think either of them will do it for liability reasons. I know at Advance we wont, but like I said, if you know someone that works there... Link to comment Share on other sites More sharing options...
scoobydoobie Posted April 25, 2009 Share Posted April 25, 2009 Or you could by a ScanGauge II and read and clear them yourself at home Link to comment Share on other sites More sharing options...
Max Capacity Posted April 26, 2009 Share Posted April 26, 2009 Can't you just remove the battery cable for a few minutes and it will reset ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
scoobydoobie Posted April 26, 2009 Share Posted April 26, 2009 Can't you just remove the battery cable for a few minutes and it will reset ? yes, but more than likely it will come back before too long Link to comment Share on other sites More sharing options...
FrozenNorthLGT Posted April 27, 2009 Share Posted April 27, 2009 Most newer vehicles unhooking the battery wont do anything for a CEL, the code is stored in the computer until a command deletes it. Link to comment Share on other sites More sharing options...
rice_rocket Posted April 27, 2009 Share Posted April 27, 2009 If you reconnect it, then once your car runs through it's own checks it will shut off by itself. If not, go to the autozone and scan it to make sure that's the problem. It certainly wouldn't hurt to disconnect the battery and start it up again to see if it'll clear it. (haven't personally tried with the 05 Legacy of mine since I do have all the cables etc to control the ECU myself ) Link to comment Share on other sites More sharing options...
Spec-B-JY Posted April 27, 2009 Author Share Posted April 27, 2009 I just reconnected it and after about 3-4 starts of my car with some driving in the middle, it went off on its own. I think it takes the computer a few start-ups to cycle through the checks and verify that everything is ok. Thanks for all the help everyone. Case closed. Link to comment Share on other sites More sharing options...
zmarko Posted April 27, 2009 Share Posted April 27, 2009 Case closed. But Matlock just got here. http://www.tagsrwc.com/matlock/images/matlock2.jpg Link to comment Share on other sites More sharing options...
ihkskim Posted May 22, 2009 Share Posted May 22, 2009 is there really a substantial diff in gains between a high flow drop in filter vs a intake (cobb) im getting a cobb dp and spt exhaust soon Link to comment Share on other sites More sharing options...
