Mindspin311 Posted April 23, 2009 Share Posted April 23, 2009 Running a Stage2 tune from Tuning Alliance. Mods are as follows... Perrin TMIC Invidia DP Perrin Mid/Y Prodrive Mufflers K&N Drop In filter Grimmspeed UP I did my best to run for 2k rpm to 7k rpm in 3rd, but there was a bit too much traffic. Temp outside was about 55-60*F. I eventually will be sending these logs to Mike to take a look at, but Id like to see what others think. Run #1 - https://filebox.vt.edu/users/justinl/DataLogs/Log1.xls Run #2 - https://filebox.vt.edu/users/justinl/DataLogs/Log2.xls Run #3 - https://filebox.vt.edu/users/justinl/DataLogs/Log3.xls Thanks for looking! Link to comment Share on other sites More sharing options...
Spec B Posted April 23, 2009 Share Posted April 23, 2009 I looked at Run#1...looks good (no knock) but you are overboosting a little bit at around 3300...19 seems like too much boost for the stock turbo. Link to comment Share on other sites More sharing options...
Mindspin311 Posted April 23, 2009 Author Share Posted April 23, 2009 Thanks for the input. Anyone else? Link to comment Share on other sites More sharing options...
Legacy_GT_Pilot Posted April 24, 2009 Share Posted April 24, 2009 The logs look good from my perspective as well - good boost and strong timing with no knock. Link to comment Share on other sites More sharing options...
Mindspin311 Posted April 24, 2009 Author Share Posted April 24, 2009 Updated the logs in Excel format Link to comment Share on other sites More sharing options...
Mindspin311 Posted April 25, 2009 Author Share Posted April 25, 2009 Infamous? MickeyD? Link to comment Share on other sites More sharing options...
mickeyd2005 Posted April 28, 2009 Share Posted April 28, 2009 Post a learning view. The ecu pulled timing in the 3rd log. However, I'm not sure if that's due to a knock that occurred in this log or if it was due to a knock event at some previous time at some different location. The stock FLKC table has a very wide range for the high end load. In the future, you should log knock sum and ignition total timing instead of your other parameters. Link to comment Share on other sites More sharing options...
Mindspin311 Posted April 28, 2009 Author Share Posted April 28, 2009 Thanks for the comments, I am downloading Learning View now. Should I reset the ECU, do some new pulls, then run Learning View? Link to comment Share on other sites More sharing options...
Mindspin311 Posted May 15, 2009 Author Share Posted May 15, 2009 So, I just tried to run Learning view and got this error [21:49:30.7290912] Learning View version 0.6a [21:49:33.7434256] op20pt32.dll not found in C:WINDOWSsystem32 [21:49:35.9165504] Opening COM1 failed: Access to the port 'COM1' is denied. Any input on that? Anyways, here is another log. Before taking this log, I reset the ECU and drove for a few mins before making the pull, so Im not sure if that effects anything or not. I did notice that my boost never hit 19psi like in previous logs. http://filebox.vt.edu/users/justinl/DataLogs/5-14-09-67deg.csv Link to comment Share on other sites More sharing options...
nka Posted May 15, 2009 Share Posted May 15, 2009 I don't see IAM in RR, it's normal ?? Are you using RR ? Link to comment Share on other sites More sharing options...
