mwiener2 Posted May 13, 2009 Share Posted May 13, 2009 you may need to have to the tune adjusted. the rip may have been there during the tune. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
car_guy1 Posted May 13, 2009 Author Share Posted May 13, 2009 you may need to have to the tune adjusted. the rip may have been there during the tune. Would that affect the tune? would reflashing the same tune make a difference? Link to comment Share on other sites More sharing options...
mwiener2 Posted May 13, 2009 Share Posted May 13, 2009 it's a vacuum leak. if it was there during the tune, then you need to have a re-tune done to fix it. re-flashing it will do nothing My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
cfdrumr Posted May 26, 2009 Share Posted May 26, 2009 any news? Link to comment Share on other sites More sharing options...
cfdrumr Posted May 29, 2009 Share Posted May 29, 2009 My car is FIXED! I went through and re-disabled the CEL codes for stage 2. Somehow I skipped over a few that were holding back the boost...Now I am hitting 18 with ease!!! Link to comment Share on other sites More sharing options...
Infamous1 Posted May 29, 2009 Share Posted May 29, 2009 My car is FIXED! I went through and re-disabled the CEL codes for stage 2. Somehow I skipped over a few that were holding back the boost...Now I am hitting 18 with ease!!! Just an FYI, CEL's do not disable or change boost in any way. Your car is not happy, your boost was gone because your IAM dropped. The reason your boost is back is because you reflashed your car which in turn reset your IAM. Your car will most likely lose boost again, it is just a matter of time. Link to comment Share on other sites More sharing options...
cfdrumr Posted May 30, 2009 Share Posted May 30, 2009 I do not think you are right on this one. I was making full boost on my stage 1 setup, the second I gutted the first DP cat the boost was gone. I flashed stage 2 and did not change a thing. I then went in and double checked all the CEL's...works now... Link to comment Share on other sites More sharing options...
mwiener2 Posted May 30, 2009 Share Posted May 30, 2009 "deleting" a cel only turns off the Check Engine light. So now, if your car is miss firing and you "deleted" that cel....It's still miss firing, but the Check engine light doesn't come on to tell you My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Infamous1 Posted May 30, 2009 Share Posted May 30, 2009 I do not think you are right on this one. I was making full boost on my stage 1 setup, the second I gutted the first DP cat the boost was gone. I flashed stage 2 and did not change a thing. I then went in and double checked all the CEL's...works now... Okay:rolleyes: Link to comment Share on other sites More sharing options...
