jayway Posted September 27, 2009 Share Posted September 27, 2009 Does anyone know of anywhere to download romraider 0.5.0? I cat seem to get ecuflash 1.29a to connect to my ECU and I want to try romraider but the latest version isn't working. I've spend hours trying and followed qikslvr's instructions. I'm a little frustrated to say the least! I need to figure this out so I can install my UP/DP and get infamous tuned. Please help. Link to comment Share on other sites More sharing options...
C Branch Posted September 27, 2009 Share Posted September 27, 2009 Just my Vag Com cable yesterday! Reformatted my laptop, installed everything and Rom Raider is working perfectly!!! Thanks to the OP and everyone in this thread for all the tips!! Link to comment Share on other sites More sharing options...
jayway Posted September 27, 2009 Share Posted September 27, 2009 Just my Vag Com cable yesterday! Reformatted my laptop, installed everything and Rom Raider is working perfectly!!! Thanks to the OP and everyone in this thread for all the tips!! ... jealous!!! Link to comment Share on other sites More sharing options...
qikslvr Posted October 1, 2009 Author Share Posted October 1, 2009 Are you sure that the drivers for the cable were installed properly and the computer is seeing the cable? If you open Device Manager(under system in control panel) and then plug in the cable; you should see a new item pop up under LPT&COM ports. It should show either a "Serial to USB Adapter", "Mosfet usb device(or something like that), or some other name depending upon which driver was used. If it does; you will need to figure out which COM Port it is assigned to. When you open RomRaider Logger; you will need to select that com port from the drop box in the upper right corner. When you do that the words in the upper left corner should change from "connecting to ECU" to reading data or something. I'm actually out of town, but will be back soon and will gladly assist when I can. Did you get a driver disc with the cable? Does anyone know of anywhere to download romraider 0.5.0? I cat seem to get ecuflash 1.29a to connect to my ECU and I want to try romraider but the latest version isn't working. I've spend hours trying and followed qikslvr's instructions. I'm a little frustrated to say the least! I need to figure this out so I can install my UP/DP and get infamous tuned. Please help. Let's kick this pig! Link to comment Share on other sites More sharing options...
jayway Posted October 2, 2009 Share Posted October 2, 2009 Thanks for the reply qikslvr! I'm using the drivers that are posted in this thread, I did get a driver disc with the cable but it doesn't work either. I was actually just messing with it and I can get learning view to read the ecu but ecuflash is still not connecting. It recognizes the cable (bottom of the window displays USB <> SERIAL) but when I hit read and then select the vehicle from the list it says the below errors... [18:35:17.172] unable to open OpenPort device [ Serial ]. [18:35:17.172] unable to connect to vehicle interface. I also dont see where you select which com port in ecuflash. Am I missing something? And should I be using the latest version of RR? I read in one of these threads that version 0.5.0 will only work with our cars but I can't find where to download it. Link to comment Share on other sites More sharing options...
qikslvr Posted October 7, 2009 Author Share Posted October 7, 2009 Are you connecting the green test connectors that are found in the passenger side footwell(top centerish behind the glovebox may be tucked under carpet in a little pocket)? Also do you have the key turned to the "ON" psoition? Let's kick this pig! Link to comment Share on other sites More sharing options...
jayway Posted October 7, 2009 Share Posted October 7, 2009 Are you connecting the green test connectors that are found in the passenger side footwell(top centerish behind the glovebox may be tucked under carpet in a little pocket)? Also do you have the key turned to the "ON" psoition? Good call asking the basic questions, you have definitely done this for a living at one point lol. Yes, I have the green connectors hooked together and ignition is in the on position (w/ fan cycling). I've uninstalled/reinstalled the drivers maybe 4 times along with ecuflash. I'm at the point of giving up Link to comment Share on other sites More sharing options...
UniqueTII Posted October 7, 2009 Share Posted October 7, 2009 I didn't read this thread in time and lost my money to them as well. I'm filing a claim with PayPal now. Link to comment Share on other sites More sharing options...
qikslvr Posted October 7, 2009 Author Share Posted October 7, 2009 Don't give up just yet. I've been meaning to do screen shots of the procedures(for this and my other thread), but have been dealing with a few family emergencies(in other cities), so I haven't had time to get it done. There are a couple things that are easier to explain with pictures than words. I use StreetTuner-Advanced most of the time personally and I don't have my old laptop that has ECUflash with me, so I will get some screen shots when I'm at home Friday. I will then work them into another version of the walkthrough and post it up here. If Learning view is working then ECUFlash should too. We just need to figure out which setting needs to be tweaked. Again, I don't have the tools or time to work with you today, but I will get you up and running when I get home and have a free minute so please hang in there just a little longer. Good call asking the basic questions, you have definitely done this for a living at one point lol. Yes, I have the green connectors hooked together and ignition is in the on position (w/ fan cycling). I've uninstalled/reinstalled the drivers maybe 4 times along with ecuflash. I'm at the point of giving up Let's kick this pig! Link to comment Share on other sites More sharing options...
jfg22557 Posted October 13, 2009 Share Posted October 13, 2009 subscribed for my future endeavors into the world of OS tuning:). Only downside is, experimental/non-tech supported technology can be frustrating as all hell sometimes, may end up Link to comment Share on other sites More sharing options...
Mega Users LieutenantDan Posted October 13, 2009 Mega Users Share Posted October 13, 2009 I spent hours trying to get my VAG-COM cable to work with my Windows Vista OS. I fiddled with every possible thing. When i plugged the cable in, the laptop automatically installed the correct driver for the cable. The only thing that allowed me to flash correctly was downloading and using ECUflash version 1.29a. Also make sure the cable is securely connected. It's pretty flimsy and can feel "connected" when it's actually not. Link to comment Share on other sites More sharing options...
jayway Posted October 13, 2009 Share Posted October 13, 2009 I finally got mine to work with Vista! I posted in the local forum that I needed some help and I got the help I needed. A guy who tunes his own car came over and after a few minutes of troubleshooting he loaded the newest version of ecuflash and hooked up his tactrix cable and it worked fine. Plugged my vag com in and it worked! RR LV and ecuflash are now working perfectly. Link to comment Share on other sites More sharing options...
qikslvr Posted October 13, 2009 Author Share Posted October 13, 2009 Cool. Glad to hear it. Again, if you can get it to work once(with any cable) it should all work from there on out. Good job. Let's kick this pig! Link to comment Share on other sites More sharing options...
knfevg Posted October 16, 2009 Share Posted October 16, 2009 I've got a EDM Impreza STi 2003 with ProDrive kit (including a new map). Using the VagCom cable I managed to datalog with RR, EcuExplorer and LearningView. Now I want to READ ONLY the current map (not writting yet). For this I've connected the green plug under the steering wheel, connected the USB to the computer and turned the key to ON. The yellow engine light was flashing and the pump was switching on and off. But, ECU FLASH couldn't read the ECU. I'm working with the latest ECUFLASH version. Any ideas? Link to comment Share on other sites More sharing options...
qikslvr Posted October 17, 2009 Author Share Posted October 17, 2009 O.K. so you've got an EDM(European? help me out) 2003 STi that you would like to READ the ECU off of. Correct? Sounds like the cable is working fine as it is currently working with all other applications. So from here it looks like you need to also get another piece of hardware from what I can gather. If your STi isn't drive by wire; then you will need a "port initiator" that will pass the flashing voltage and end-line signal to the ECU. At least this is the case for USDM vehicles of the same year and model. Yours may be different, so you might want to scan the OpenECU forum for more info on your specific model. Here is a link to the part that is needed for USDM vehicles: http://www.tactrix.com/product_info.php?products_id=33 Check it out and let us know what you find... Let's kick this pig! Link to comment Share on other sites More sharing options...
LittleBlueGT Posted October 19, 2009 Share Posted October 19, 2009 I was too lazy to read. Will this VAG-COM cable work with CAN-BUS ECUs for the purpose of logging and LV? If so, where is everyone buying them? Thanks Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
qikslvr Posted October 20, 2009 Author Share Posted October 20, 2009 It posted in the first(and other) posts that this cable WILL NOT WORK TO READ OR FLASH CAN-BUS ECU's. I believe that the Tactrix v2 cable is the only option for the CAN-BUS ECU's at the moment. Learning View actually reads a table from the ECU so I'm pretty sure it won't work. As for logging I'm not sure. Let's kick this pig! Link to comment Share on other sites More sharing options...
LittleBlueGT Posted October 20, 2009 Share Posted October 20, 2009 It posted in the first(and other) posts that this cable WILL NOT WORK TO READ OR FLASH CAN-BUS ECU's. I believe that the Tactrix v2 cable is the only option for the CAN-BUS ECU's at the moment. Learning View actually reads a table from the ECU so I'm pretty sure it won't work. As for logging I'm not sure. I did read that. I didn't really consider LV or logging to be reading. FWIW my 1.3 Tactrix cable works to do both on the CAN-BUS ECUs. If that is the case, will the VAG-COM also work? Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
qikslvr Posted October 20, 2009 Author Share Posted October 20, 2009 I did read that. I didn't really consider LV or logging to be reading. FWIW my 1.3 Tactrix cable works to do both on the CAN-BUS ECUs. If that is the case, will the VAG-COM also work? I actually use my APv1 cable and ST-A to do everything on my car and rarely, if ever; use the VAG-COM cable for anything(other than to create these threads). I guess I did try to use this cable to log about a year ago on an 08 WRX and couldn't connect with it, but I didn't spend much time messing with it as someone else there had a Tactrix v2 cable that worked right off. Maybe someone else could give it a try and report back. Is that v1.3 Tactrix cable a serial connection or a USB(tan or black)? Let's kick this pig! Link to comment Share on other sites More sharing options...
LittleBlueGT Posted October 20, 2009 Share Posted October 20, 2009 I actually use my APv1 cable and ST-A to do everything on my car and rarely, if ever; use the VAG-COM cable for anything(other than to create these threads). I guess I did try to use this cable to log about a year ago on an 08 WRX and couldn't connect with it, but I didn't spend much time messing with it as someone else there had a Tactrix v2 cable that worked right off. Maybe someone else could give it a try and report back. Is that v1.3 Tactrix cable a serial connection or a USB(tan or black)? black, and it is USB Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
knfevg Posted November 3, 2009 Share Posted November 3, 2009 O.K. so you've got an EDM(European? help me out) 2003 STi that you would like to READ the ECU off of. Correct? Sounds like the cable is working fine as it is currently working with all other applications. So from here it looks like you need to also get another piece of hardware from what I can gather. If your STi isn't drive by wire; then you will need a "port initiator" that will pass the flashing voltage and end-line signal to the ECU. At least this is the case for USDM vehicles of the same year and model. Yours may be different, so you might want to scan the OpenECU forum for more info on your specific model. Here is a link to the part that is needed for USDM vehicles: http://www.tactrix.com/product_info.php?products_id=33 Check it out and let us know what you find... Just got back to trying this. Two questions: 1. Do I need this plug just to READ the ECU? I'm not trying to flash yet, just reading... 2. Any way I can make this plug in DIY method? Link to comment Share on other sites More sharing options...
nghtriderv3 Posted November 4, 2009 Share Posted November 4, 2009 How do i know if my car has an CAN-BUS ECU? its a 05 legacy gt. i just ordered the vag-com cable cuz my computer cant connect with my accessport set up. Link to comment Share on other sites More sharing options...
qikslvr Posted November 4, 2009 Author Share Posted November 4, 2009 If it's an 05 is an OBDII bus. The CAN-BUS is on the newer models. Let's kick this pig! Link to comment Share on other sites More sharing options...
knfevg Posted November 5, 2009 Share Posted November 5, 2009 I tried today several things:ECUFlash 1.42 ECUFlash 1.29aWith shorting the pins of the white terminalwithout shorting the pinsclicking OK after switching the key to ONClicking OK BEFORE switching the key to ON Here are the results:1.29a DIDNT WORK AT ALL. Here is the error I got: [01:12:01.640] Version 1.29.906[01:12:01.656] 8 memory models read.[01:12:02.921] 140 ROM metadata models read.[01:12:02.921] checksum module "subarudbw" loaded.[01:12:02.921] flashing tool "wrx02" loaded.[01:12:02.921] flashing tool "wrx04" loaded.[01:12:02.921] flashing tool "sti04" loaded.[01:12:02.921] flashing tool "sti05" loaded.[01:12:02.921] flashing tool "mitsukernel" loaded.[01:12:02.921] flashing tool "mitsukernelocp" loaded.[01:12:02.921] flashing tool "mitsubootloader" loaded.[01:12:07.312] unable to open OpenPort device [ Serial ].[01:12:07.312] unable to connect to vehicle interface. With version 1.42 more luck. When I choose 2003-2005 NONUSDM, I get this error:[12:40:59.718] Using interface USB <-> Serial[12:41:01.875] denso02_bootloader_cmd_start[12:41:03.109] denso02_bootloader_cmd_start[12:41:04.343] denso02_bootloader_cmd_start[12:41:05.578] denso02_bootloader_cmd_start[12:41:06.812] denso02_bootloader_cmd_start[12:41:07.250] kernel get version[12:41:07.578] interface close[12:41:07.578] interface close When I choose 2004-2005 USDM WRX, here is what I get:[12:40:48.875] Using interface USB <-> Serial[12:40:50.000] kernel get version[12:40:50.390] SSM2 init[12:40:50.546] SSM2 ECU ID is 29 44 59 61 05[12:40:52.578] interface close[12:40:52.578] interface close The white block has no effect at all.Any ideas? I have the ProDrive kit (including ECU flash). I know that some have a problem reading it. What error should I get if it's locked? Link to comment Share on other sites More sharing options...
GTTuner Posted November 13, 2009 Share Posted November 13, 2009 I downloaded romraider and ecuflash, in romraider it keeps on telling me i need to download the definitions. and i did. but it keeps telling me i still need to do so. I dont understand what is going on Same problem here on my Vista lap top. Used my Ol' XP laptop and works perfect! Link to comment Share on other sites More sharing options...
