aigochamaloh Posted April 21, 2009 Share Posted April 21, 2009 Is the USDM Spec.B suspension assembly a bolt on to a 2.5GT or 2.5i? It would be a complete swap, and I'm hoping it's a simple unbolt and swap, then bolt up. Link to comment Share on other sites More sharing options...
katalyst Posted April 21, 2009 Share Posted April 21, 2009 for the most part yes, you need the spec B tophats; that's about the only major difference.........i think, but i've never done it myself. so someone else should probably comment. Link to comment Share on other sites More sharing options...
Paisan Posted April 21, 2009 Share Posted April 21, 2009 If you unbolt the whole thing, including top hats, you will be fine. -mike Link to comment Share on other sites More sharing options...
aigochamaloh Posted April 21, 2009 Author Share Posted April 21, 2009 If you unbolt the whole thing, including top hats, you will be fine. -mike Ok thanks, these will be with tophats included. I just wasn't sure from everything I was reading and no one seemed to do a complete swap, rather just taking the Bilstein inserts and etc. Link to comment Share on other sites More sharing options...
Paisan Posted April 21, 2009 Share Posted April 21, 2009 Yeah we've done this at our shop for several folks. You are all set if you have them complete. -mike Link to comment Share on other sites More sharing options...
