SubGacy Posted April 19, 2009 Share Posted April 19, 2009 Hi yesterday i change my frond disk brack and i saw the coil spring is broken. i want to change it but maybe i can change it for a lowering coil spring. i'm looking for a plug and play kind (without a lot of modification) witch one is the best and good for a long time. Best Regards Link to comment Share on other sites More sharing options...
Platinum_Racing Posted April 20, 2009 Share Posted April 20, 2009 If you go with lowering springs you might need a camber correction kit. Just to forewarn you. Lowering springs are available from Eibach for that car . http://www.modacar.com/products/Subaru/Legacy/Springs I'd look around for better prices though. I'm not even sure those are for your exact model. Those might be for a wagon. I think they're probably the same but you should really check it out first. Link to comment Share on other sites More sharing options...
