DELIA Posted April 19, 2009 Share Posted April 19, 2009 i went to change my fuel filter,test drove it,it drove like it should,next morning went to supermarket got home that night,went to start it blinking car wouldnt start any suggestions would be much appreciated Link to comment Share on other sites More sharing options...
Gimpy117 Posted April 19, 2009 Share Posted April 19, 2009 what exactly did it do? did it try to turn over? did it just click? do your cabin lights come on? we need a bit more to go on here... Link to comment Share on other sites More sharing options...
DELIA Posted April 20, 2009 Author Share Posted April 20, 2009 sorry,my car turns over,all the cabin lights turn on,il just try the pump and get back to you,it didnt try and start,the motor just turns over Link to comment Share on other sites More sharing options...
Platinum_Racing Posted April 20, 2009 Share Posted April 20, 2009 Make sure you're not leaking fuel on the ground. If you changed the filter the hose might have come off. Once you've checked that I'd check the ignition system and see if the coil is putting out a spark. Link to comment Share on other sites More sharing options...
DELIA Posted April 20, 2009 Author Share Posted April 20, 2009 ok shall do,i took the the hose off from the filter turned ignition on no fuel coming thru im gona test the fuel pump!you maybe on to something there (coil) Link to comment Share on other sites More sharing options...
