havanisda Posted April 18, 2009 Share Posted April 18, 2009 Any1 know what the weight differences are between Racing Brake, StopTech, DBA 4ks, etc. re:OEM sized rotors? R they all basically 5 lbs lighter per rotor vs. stock? TIA Braille B2015, RBS grill, Borla CBE, Zero/Sports rad shroud, Hayden TC, Group A crank & alt pulley - Mike Link to comment Share on other sites More sharing options...
ewhite06 Posted July 16, 2009 Share Posted July 16, 2009 bump Link to comment Share on other sites More sharing options...
Th3Franz Posted July 16, 2009 Share Posted July 16, 2009 between 2-pc rotors? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
ewhite06 Posted July 16, 2009 Share Posted July 16, 2009 OEM, StopTech, DBA...whatever. I wasn't thinking about 2-piece rotors - they would be overkill on my 'spirited daily driver.' Its more for curiosity than anything else. Of course cutting out some weight would be nice... Link to comment Share on other sites More sharing options...
lvethesnow Posted July 16, 2009 Share Posted July 16, 2009 dont know the weights. but when i put on my DBA 4000XS, it felt like the dba fronts were heavier than stock, but the dba rears were lighter than stock History does not entrust the care of freedom to the weak or timid People sleep peacefully at night cause rough men stand ready to do violence on there behalf Link to comment Share on other sites More sharing options...
Th3Franz Posted July 16, 2009 Share Posted July 16, 2009 The DBA 4000 are heavier than stock. This is because they are THICKER which is better from a heat and durability standpoint. Lighter rotors are ok as long as it's not sacrificing heat capacity. This is why 2-pc rotors are so nice. The hats are extremely lightweight while the rotor itself is still beefy. On a spirited daily driver, I don't think you would notice a couple lb difference per rotor. Get whatever is the best value. I really like my DBAs but they might be slightly overkill for solely street use. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
