Erickson00 Posted April 17, 2009 Share Posted April 17, 2009 Anyone have any special tricks or tips to get my engine cover to fit properly? I can't get it aligned with all four holes to insert the plastic screws. Only three will fit; the one closest to the passenger seat is about 1/4 inch off. Is it possible mine is warped somehow? Any suggestions? Thanks! Link to comment Share on other sites More sharing options...
2008SUBYDOO Posted April 18, 2009 Share Posted April 18, 2009 Maybe 1 of the brackets is slightly bent? Link to comment Share on other sites More sharing options...
05pearl Posted April 18, 2009 Share Posted April 18, 2009 Sometimes putting in the popits in, in a different order helps. I usually fasten the top first (closest to passenger and driver) and then work on the bottom two. If one hole is slightly off, make sure the plug in the popit is backed all the way out and the prongs are pushed together to fit into the hole, angle the popit into the hole all the way before fastening the center part down. Link to comment Share on other sites More sharing options...
captainhook Posted April 18, 2009 Share Posted April 18, 2009 Anyone have any special tricks or tips to get my engine cover to fit properly? I can't get it aligned with all four holes to insert the plastic screws. Only three will fit; the one closest to the passenger seat is about 1/4 inch off. Is it possible mine is warped somehow? Any suggestions? Thanks! I doubt yours is warped, the fitment sucks from the factory. I've had to wrestle mine on every since I bought the car. I can't tell you how many ways I've tried to get it on or how many pop-its I've gone through. It's just a PITA, period. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 19, 2009 Share Posted April 19, 2009 Leave it off. You don't need it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
05pearl Posted April 19, 2009 Share Posted April 19, 2009 Leave it off. You don't need it. Didn't you hear; it ducts air straight into the intercooler and adds 25 hp Link to comment Share on other sites More sharing options...
mccorry Posted April 19, 2009 Share Posted April 19, 2009 Mine never fit right... so I just removed the brackets and run without it. I never liked it that much, anyhow. Link to comment Share on other sites More sharing options...
Lesbaru Posted April 19, 2009 Share Posted April 19, 2009 I just noticed that mine is sitting on their WITHOUT any brackets at all. Where could I find a part number and order online? Link to comment Share on other sites More sharing options...
Max Capacity Posted April 19, 2009 Share Posted April 19, 2009 I just noticed that mine is sitting on their WITHOUT any brackets at all. Where could I find a part number and order online? That would be your local friendly Subaru stealer. Just cleaned out one of the sheds today and came across mine stuck behind some old chair under cardboard. It's been there almost 5 years. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Wang Lung Posted April 21, 2009 Share Posted April 21, 2009 That would be your local friendly Subaru stealer. Just cleaned out one of the sheds today and came across mine stuck behind some old chair under cardboard. It's been there almost 5 years. You could probably sell that if you were inclined, M.C. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 23, 2009 Share Posted April 23, 2009 Who would want the thing? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
