clicking noise (axles, transmission?) please help
BLACKonBLACK Limited
2005 legacy gt 5mt. 45k
never launched stage 2.5 but driven aggressively
I have been hearing a clicking noise while decelerating, in gear and out of gear. Sounds like bad U joints, but the sound is coming from the tranny or at least seems like it is also the noise is speed dependent clicks faster when you going faster and clicks slower as you come to a stop. Also my clutch has been on its last leg for the last few months now and I am worrying it caused some issue with the transmission.
The clutch has slipped a few times and is releasing really close to the floor, also there is hardly any play in the clutch now, its either engaged out disengaged no area for play. I started hearing this noise after i switched to Subaru extra S fluid.
It seems to me the clutch is definitely toast which i already figured but could that be causing the clicking noise i hear? the price of a clutch/install is pushing my financial limits as is....
Anyone have any ideas?
Thank you.
Could be lots of things.
Just how bad is the clutch? If it's slipping REALLY badly, it could actually be slipping on decel, and that would definitely make noise.
Try to locate the noise a little better, and we'll see if we can't trace it down.
[URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard
How fast are you going when it makes the click? Click when turning?
  • 1 month later...
  • 1 month later...
Is this normal? Still trying to figure this noise out
[ame=http://www.youtube.com/watch?v=XypxVOXa6_4]YouTube - driveshaft[/ame]
[ame=http://www.youtube.com/watch?v=JP45uFNZSaU]YouTube - noise when decelerating[/ame]
  • 1 month later...
how fast are you going while it's making noise? Today I just started hearing a speed dependant click at 20mph on decel. Clutch engaged or not...
Okay, I lied. It clicks on decel around 20mph only when the clutch is disengaged (pedal to the floor). I have a 06/07 WRX Flywheel and ACT HD Clutch Disc installed.
I have the same noise on my 60k 06 Spec B trans. It is in the process of being torn down at the dealership as I had it checked at 59.5k although it had been going on for several weeks. Servicing the transmission had NO effect what so ever. Several trained ears seem to think it may possibly be the bearings on the center diff. We put a stethoscope on in it in the air and the noise is coming from the center/rear end of the trans. However in a day or so when it's in pieces, we will know for sure. I will keep you posted.
Well, I had my car at the dealership for a week. They have been unable to get to it yet since they fired one of their techs (Ryan Davis). They only have one real technician now working on Subarus.... I have picked up my car and am now driving it until they can get me in again. Lovely, I know, but I would rather be driving it versus it sitting there. Especially since I know it's nothing that will blow up anytime soon at least. So I have no news as of yet... If it wasn't going to be covered under warranty, I would just have Ryan tear it apart at the shop, but alas.. with a new baby, I can't afford to spend much. So I will just have to wait in line to get my car worked on. I'll update as soon as I can..
