DaveZ Posted April 16, 2009 Share Posted April 16, 2009 I've got the bilsteins & will be installing Rallitek springs next week - has anyone done this & NOT cut bumpstops, or is it pretty much required - Rallitek says they drop about .9 inches. Link to comment Share on other sites More sharing options...
jagcars26 Posted April 16, 2009 Share Posted April 16, 2009 I don't think it's required fr any springs,cutting the bumpstops just increases the amount of travel for the struts. I'm doing the same thing next week Dave but with Bilsteins and pinks and I will be cutting the bumpstops before I start the install. Somebody will correct me if I'm wrong. Link to comment Share on other sites More sharing options...
DaveZ Posted April 16, 2009 Author Share Posted April 16, 2009 yeah the original post about cutting the stops was in ref to the tein H & swifts which are a larger drop (1.5") than the rteks or pinks, which are about 1". Just wondering how necessary it is & what the downside might be with different springs. Link to comment Share on other sites More sharing options...
DaveZ Posted April 17, 2009 Author Share Posted April 17, 2009 Got my answer post #79 - no need says Rallitek http://legacygt.com/forums/showthread.php?t=77831&page=6 Link to comment Share on other sites More sharing options...
jagcars26 Posted April 17, 2009 Share Posted April 17, 2009 Now I'm questioning weather I should cut the bump stops with the pinks? Anyone? Link to comment Share on other sites More sharing options...
terrangama Posted April 17, 2009 Share Posted April 17, 2009 I personally think you will be ok with not cutting them. Worst case scenario is that it does suck and you have to cut them later. Link to comment Share on other sites More sharing options...
Andreu Posted April 24, 2009 Share Posted April 24, 2009 I have spec b's with the rallietek. Did not cut the bump stops and i dodnt have any problems. Link to comment Share on other sites More sharing options...
katalyst Posted April 24, 2009 Share Posted April 24, 2009 i think the rallitek springs offer enough strut travel that the bump stops do not have to be modified. for others ie. swifts, it would probably be favorable to do the bumpstop mod Link to comment Share on other sites More sharing options...
DaveZ Posted April 25, 2009 Author Share Posted April 25, 2009 /\ absolutely corrrect RE the ralliteks, they dropped my rear only half an inch, the fronts a quarter. They are great springs to match with bilsteins for handling as you dont lose much if at all in stroke. Link to comment Share on other sites More sharing options...
