sschmelcke Posted April 12, 2009 Share Posted April 12, 2009 i just ordered a stock subwoofer. i see 2 front bolts for the front seats but where on earth are the rear bolts? also anyone have a write up on how to take the dash apart? thanks Link to comment Share on other sites More sharing options...
rtbrjason Posted April 12, 2009 Share Posted April 12, 2009 i just ordered a stock subwoofer. i see 2 front bolts for the front seats but where on earth are the rear bolts? also anyone have a write up on how to take the dash apart? thanks Rear bolts for the seat are covered by square-ish plastic caps. They pull pretty much right off and you will see the bolts. I've seen a couple dash panel removal walk throughs floating around this forum. It's really pretty easy. Pop the center console up so you can pop the plastic around the shifter up and unscrew the bottoms of the 2 silver/wood trims pieces that run up the sides. Those will then pop out and you should see 4 screws holding the deck in. Link to comment Share on other sites More sharing options...
sschmelcke Posted April 12, 2009 Author Share Posted April 12, 2009 awesome. thanks. i tried searching but didnt have much luck so i will try again. Link to comment Share on other sites More sharing options...
ur a bus Posted April 12, 2009 Share Posted April 12, 2009 The sub comes with EXCELLENT instructions for removing the radio and dismantling the console. -- Steve Link to comment Share on other sites More sharing options...
sschmelcke Posted April 12, 2009 Author Share Posted April 12, 2009 cool. i did not know that. im actually downloading the pdf now. Link to comment Share on other sites More sharing options...
