mpiotro Posted April 11, 2009 Share Posted April 11, 2009 Any ideas? I could not find anything in vac pics. The car had Sirius before I bought it. Previous owner admitted he heard something pop (i.e. shorted something) when removing the Sirius. All radio AND HVAC controls work perfectly. Just to clarify before we go down this road- this is definitely NOT related to DRL or Illumination switch. Straight up no backlighting anytime, ever!. The HVAC and radio displays are perfect- just NO backlighting for either. Before I tear center console apart... have any ideas? There are no blown fuses on interior, maybe just the backlighting bulbs blew??? Is there a backlighting relay or inline fuse? Any idea what type of bulb they use? Link to comment Share on other sites More sharing options...
darkside Posted April 12, 2009 Share Posted April 12, 2009 I had that problem when added mtx ReQ, No Illumination on radio, but it was the ground wire on the harness came off the stock plug.. Pull out you radio and check to make sure all wires are in the harness plugs and back of radio.. Also check you fuses inside and fuses by motor.. Sometimes the wires pull out of the harness. Hope this helps Link to comment Share on other sites More sharing options...
