PLEASE Identify this part.....
On my 99 brighton leg 2.2/ EJ22 motor ; front of motor, on top, just behind the drive belt, (standing in front of car) slightly left of center, just in front of the engine I.D. stamp (EJ22) looks like a bolt , its 24 mm, it has a two wire metal, "L" shaped connector right on top. It appears to be leaking a little oil. WHAT IS IT?!? AND WHAT DOES IT DO?!? :spin:
Sounds like the oil pressure switch.
Crank position sensor. Isn't the oil pressure switch on the back of the motor? It's been a REALLY long time since I played with an EJ22.
[URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard
yep. are you sure it's leaking from there and not the power steering? Having that leak is pretty rare unless someone messed with it.
No I am not positive the oily build up surounding the sensor isn't from above, good point, I will investigate further. It does look like a sort of pressure switch though, know that it has been mentioned.
