1998 LGT wagon turbo option??
pmag220
Don't bother. The 2.5l does NOT do well with boost. You will spend about the same money and have a 100x more reliable motor if you just swap the motor for a 22t or something meant for a turbo.
That being said, AVO makes a turbo kit for newer 2.5's that will fit on the older ones with little to no modification. You'll find it on rallitek.com.
But since you haven't bought the car yet, I'd recommend just buying something that came turbo stock. You'll spend less money that way.
  • 4 weeks later...
Good luck trying to find a EJ22T...
Second...
However, I have the AVO Turboworld kit installed on my '99 Legacy GT and it works VERY well. Many people have the same opinion as the two previous posters do about not going with an aftermarket turbo but these AVO turbo kits are made specificially for this engine and thoroughly tested. Sean at Rallitek had this same kit on his 2.5RS for over 6 years and never had any problems. It was his daily driver AND he tracked it on the weekends... I've had absolutely zero problems with this kit so far myself...
So, just to let you know, there is some hope out there if you'd like to go this route. Plus, its awesome having something that very few other people have. :)
P.S. Sorry to bring a complete dead thread back to life...
My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters!
http://cgi.ebay.com/ebaymotors/Subaru-Impreza-Legacy-EJ22T-2-2L-TURBO-Engine-and-more_W0QQcmdZViewItemQQcategoryZ33615QQihZ012QQitemZ220405960013QQrdZ1QQsspagenameZWDVW
http://cgi.ebay.com/ebaymotors/Subaru-Impreza-Legacy-EJ22T-2-2L-TURBO-Engine_W0QQcmdZViewItemQQcategoryZ33615QQihZ012QQitemZ220407825468QQrdZ1QQsspagenameZWDVW
http://cgi.ebay.com/ebaymotors/Reman-90-98-Subaru-2-2-EJ22-EJ22T-Long-Block-Engine_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ33615QQihZ018QQitemZ8040522967QQrdZ1QQsspagenameZWD1V
The EJ22T has a completely closed deck...
EJ25 Turbo.... (Cracked cylinder bore. Note the crack breaches the water jacket)
http://i5.photobucket.com/albums/y170/amorton-25rs/engine/engine015.jpg
EJ22T block. (Note how this one isn't cracked. Note the closed upper deck where the EJ25's water jackets would be.)
http://i5.photobucket.com/albums/y170/amorton-25rs/engine/enginetest.jpg
BTW: If he got an EJ22 from an 01 Imprezza it would be OBDII compliant I believe.
Wow. 3 year unlimited mile warranty. That's pretty damn good. Little pricey but good. And yes. I believe you are correct on the 01 Impreza being OBDII.
You know what did that engine in, the Fram oil filter. ;)
OBDII became mandatory for MY '96 and newer, though some cars like the '95 Legacy had it.
Friends don't let friends drink cheap beer.
Exactly correct. In fact, I believe the Legacy was the only '95 Subaru that did have the OBDII... I could be wrong though.
The one problem with the 22T is it's quite limited... I wouldn't run a stock 22T myself, the reason they are so bulletbroof is cause they are so, well, over engineered, to be as polite as possible. They must have the smallest turbo ever seen on an EJ, heck, probably the size of a TT turbo, SOHC, comparatively high compression ratio and no intercooler. i can't imagine how N/A like that power curve is.
If you're on a budget, they will make a fantastic base for future mod's, but if you a bit of cash to spare, i would seriously consider doing a nice low compression, big turbo, DOHC build. I've got a similar build, using an EJ20G closed deck block, with 8.5:1 pistons, forged rods, and EJ20R DOHC heads, with a VF39 to power it, and my god is that a fun engine, nothing quite like 20psi boost to 8000 rpm :D
